JAM2014
| Multi-part logic...... |
Posted: Mon Apr 16, 2018 4:22 pm |
Hi All,
I'm trying to code a test for dates that fall within a certain date range, but a simple & obvious method is defying me at the moment.
Let's suppose I want to find out if a specific date falls between two end point dates, say March 11th & Nov. 4th. I've been able to code a test that works for the beginning date or the end date separately, but I haven't been able to combine them into a working piece of code that tests both date limits! Argh!!!
Here is a test program that I'm trying to make work!
#include <18F44K22.h>
#fuses INTRC_IO, NOWDT, PUT, NOLVP, NOPBADEN, FCMEN
#use delay(clock=8000000)
#define PWR_LED Pin_B1
#define Serial_TxD Pin_B4 // serial debug port
#use rs232(baud=9600, xmit=Serial_TxD, stream = Diag)
int8 iIndex;
signed int8 UTCOffset = 0;
unsigned int16 iMonth = 0;
unsigned int16 iDay = 0;
unsigned int8 iDayMax = 0;
// Here we turn off the Pwr LED
output_low(PWR_LED);
// Here we blip the Power LED at power-up to show that the Lighting interface is working
for ( iIndex = 0 ; iIndex < 3 ; iIndex++ )
output_high(PWR_LED);
delay_ms(250);
delay_ms(250);
// Here we leave the Power LED ON
for (iMonth = 1; iMonth <= 12; iMonth++)
switch (iMonth)
Case 1:
Case 3:
Case 5:
Case 7:
Case 8:
Case 10:
Case 12:
iDayMax = 31;
Case 2:
iDayMax = 28;
Case 4:
Case 6:
Case 9:
Case 11:
iDayMax = 30;
for (iDay = 1 ; iDay <= iDayMax ; iDay++)
//Here we do the UTC offset correction!
if (((((iMonth >= 3) && (iDay >= 11)) || (iMonth > 3))) && ((((iMonth <= 11) && (iDay <= 4)) || (iMonth < 11))))
UTCOffset = -4;
UTCOffset = -5;
fprintf(Diag, "Month: %Lu Day: %Lu UTCOffset: %d\n\r", iMonth, iDay, UTCOffset);
while(1){}
Any input on the proper test I need to be performing to make the this code work as intended?
Thanks!
Jack
Joined: 01 Jul 2010 Posts: 9619 Location: Greensville,Ontario
Posted: Tue Apr 17, 2018 5:37 am |
//function to decide if DST or EST
void dst_calc() {
if((rtcdow==0) && (rtcmth==3)&&(rtcday>=8)&&(rtcday<=16)&&(rtchrs==0)&&(rtcmin==0)&&(rtcsec==0)&&(dstflg==0))
rtchrs=rtchrs+1;
//ds3231_set_date_time(rtcyer,rtcmth,rtcday,rtcdow,rtchrs,rtcmin,rtcsec); //spring ahead !
dstflg=1;
lcd_gotoxy(15,2);
printf(lcd_putc,"DST");
//add rtc eeprom saving here !
else if ((rtcdow==0) && (rtcmth==11)&&(rtcday>=1)&&(rtcday<=8)&&(rtchrs==00)&&(rtcmin==0)&&(rtcsec==0)&&(dstflg==1))
rtchrs=rtchrs-1;
//ds3231_set_date_time(rtcyer,rtcmth,rtcday,rtcdow,rtchrs,rtcmin,rtcsec); //spring ahead !dstflg=0;
dstflg=0;
lcd_gotoxy(15,3);
printf(lcd_putc,"noDST");
//add rtc eeprom storing here !
variables rtcxxx are the data from the rtc module,dtslfg is the daylight savings time flag.
OK, here's a quick cut and paste from my chickencoop project
It ain't pretty but I'll get back to it AFTER I get 'sunset' to be correct.
Got 18/4/13 to be correct( 20:00 instead of -4:00) by changing the 'loop' that put hrs within 0 to 24) but it fails around day 160ish..sunset at -3:00 !
JAM2014
Posted: Tue Apr 17, 2018 2:08 pm |
Hi All,
I needed to get away from this problem for a while to clear my head and be able to 'see the forest thru the trees'! Anyway, I've got the code working, and I've updated the original post with working code!
I haven't done much time/date arithmetic, but it always seems to be pretty gnarly!
Thanks,
Jack |
Posted: Tue Apr 17, 2018 7:25 pm |
| yes, you can lose a LOT of sleep over 'time math' ! Back when RAM and EPROMs were pricey, I figured out how to store time in 1 byte. As long as you're OK with 15 minute 'intervals', you can do it in 7 bits, leaving a bit to be the 'control' bit to turn a device on or off. Being one byte makes 'time math' a lot easier and faster,especially when using PICs ! |
