External Oscillator Config Registers
lastproject
PostPosted: Thu Apr 05, 2018 11:03 am     Reply with quote
Hello all,
I'm starting a new project and I'm quite unsure if my configuration for the external Oscillator are right, might somebody have a look over it please ? Smile
I'm using a dsPIC33EP512GM710 and MPLAB X IDE 4.15.
The external Oscillator has 8MHz.
I did the configuration with the "set configuration bits" in MPLAB:
// FICD
#pragma config ICS = PGD1               // ICD Communication Channel Select bits (Communicate on PGEC1 and PGED1)
#pragma config JTAGEN = ON              // JTAG Enable bit (JTAG is enabled)
// FPOR
#pragma config BOREN = ON               // Brown-out Reset (BOR) Detection Enable bit (BOR is enabled)
#pragma config ALTI2C1 = OFF            // Alternate I2C1 pins (I2C1 mapped to SDA1/SCL1 pins)
#pragma config ALTI2C2 = OFF            // Alternate I2C2 pins (I2C2 mapped to SDA2/SCL2 pins)
#pragma config WDTWIN = WIN25           // Watchdog Window Select bits (WDT Window is 25% of WDT period)
// FWDT
#pragma config WDTPOST = PS32768        // Watchdog Timer Postscaler bits (1:32,768)
#pragma config WDTPRE = PR128           // Watchdog Timer Prescaler bit (1:128)
#pragma config PLLKEN = ON              // PLL Lock Enable bit (Clock switch to PLL source will wait until the PLL lock signal is valid.)
#pragma config WINDIS = OFF             // Watchdog Timer Window Enable bit (Watchdog Timer in Non-Window mode)
#pragma config FWDTEN = OFF             // Watchdog Timer Enable bit (Watchdog timer enabled/disabled by user software)
// FOSC
#pragma config POSCMD = XT              // Primary Oscillator Mode Select bits (XT Crystal Oscillator Mode)
#pragma config OSCIOFNC = OFF           // OSC2 Pin Function bit (OSC2 is clock output)
#pragma config IOL1WAY = ON             // Peripheral pin select configuration (Allow only one reconfiguration)
#pragma config FCKSM = CSDCMD           // Clock Switching Mode bits (Both Clock switching and Fail-safe Clock Monitor are disabled)
// FOSCSEL
#pragma config FNOSC = PRI              // Oscillator Source Selection (Primary Oscillator (XT, HS, EC))
#pragma config PWMLOCK = ON             // PWM Lock Enable bit (Certain PWM registers may only be written after key sequence)
#pragma config IESO = OFF               // Two-speed Oscillator Start-up Enable bit (Start up with user-selected oscillator source)
// FGS
#pragma config GWRP = OFF               // General Segment Write-Protect bit (General Segment may be written)
#pragma config GCP = OFF                // General Segment Code-Protect bit (General Segment Code protect is Disabled)
Many thanks in Advance
Cheers!
PostPosted: Thu Apr 05, 2018 11:50 am     Reply with quote
This is Microchip XC16 compiler code. It's not CCS compiler code.
You should look for answers on the Microchip forum:
http://www.microchip.com/forums/Forums
lastproject
PostPosted: Thu Apr 05, 2018 12:34 pm     Reply with quote
Oh sorry, I posted here because on microship my Posts are not beeing actived since Im a "newbie"..
