makito013
PIC 18F27K40 RDA does not work |
Posted: Tue Mar 27, 2018 12:13 pm |
I am doing a project and unfortunately to change the project pic to the PIC18F27K40 the RDA stopped working, I tried to carry out a new project only with the RDA turning on an LED and it still does not work, could anyone help me?
Quote: | Português-BR:
Estou realizando um projeto e infelizmente ao troca o pic do projeto para o PIC18F27K40 o RDA parou de funcionar, tentei realizar um novo projeto somente com a RDA acendendo um LED e mesmo assim não funciona, alguém poderia me ajudar? |
Code: main.c
#include <main.h>
#INT_RDA
void RDA_isr(void)
output_toggle(PIN_B4);
enable_interrupts(INT_RDA);
Code:main.h
#include <18F27K40.h>
#device *ADC=10
#FUSES NOEXTOSC //External Oscillator not enabled
#use delay(internal=64MHz)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=PORT1,enable=PIN_C5)
gaugeguy
Posted: Tue Mar 27, 2018 12:29 pm |
You are going to need to use #pin_select. This processor uses pps and there is a sticky at the top of the forum page detailing its use. |
makito013
Posted: Tue Mar 27, 2018 12:57 pm |
gaugeguy wrote: | You are going to need to use #pin_select. This processor uses pps and there is a sticky at the top of the forum page detailing its use. |
could you give me an example? |
Posted: Tue Mar 27, 2018 1:24 pm |
The example is in the post at the top of the forum.....
<http://www.ccsinfo.com/forum/viewtopic.php?t=55097>
For your chip:
#PIN_SELECT U1RX=PIN_C7
#PIN_SELECT U1TX=PIN_C6
#use rs232(baud=9600,parity=N,UART1,bits=8,stream=PORT1,enable=PIN_C5)
