Clock with pic18f4550
fmeira76
PostPosted: Sat Mar 17, 2018 8:24 pm     Reply with quote
Hello, i'm trying to implement a code from a clock using a pic 18f4550 from a kit (acepro 3.0). I already have a part of the code almost ready, I would like to know a way to implement the function that adjusts the clock hours, I can not do this. please, help!
PostPosted: Sat Mar 17, 2018 10:41 pm     Reply with quote
Debounce a Switch and Increment a value ? (2-page thread)
http://www.ccsinfo.com/forum/viewtopic.php?t=43803
Push-Button code for CCS:
http://www.ccsinfo.com/forum/viewtopic.php?t=23837
fmeira76
PostPosted: Sun Mar 18, 2018 7:34 am     Reply with quote
i'd like to implement three buttons, one called "adjust button"(to active the adjust function), and other two to adjust the dozen and units of my clock parameters
PostPosted: Sun Mar 18, 2018 8:35 am     Reply with quote
If you're clever or cheap, you can use just ONE button to adjust the time on a clock. It only requires the PB to be on an external interrupt pin. I do this for my single digit LED clock.
Jay
