SOLVED: PIC24 pointer types do not match
adcor
PostPosted: Mon Mar 12, 2018 6:19 pm     Reply with quote
Maybe is a trivial error I do not see, if someone can spot it for me. I am working on a project with PIC24FJ128GA006 and CCS 5.076 compiler.
The compiler complains of mismatching pointer types. Even a strlen can not work. On a PIC18F4550 platform without _attribute_((packed)) it works.
The code is quite huge but here are my defines:
Data definition:
#define ALL_MENU  39 //total menus
typedef struct __attribute__((packed)){
             unsigned  int8 MenuID;
             unsigned  int8 SubMenu;
             unsigned int8 MenuName[23];
            } TypeMenu;
TypeMenu MenuPointer[3];
TypeMenu MenuGeneral[ALL_MENU]
   ={{_,_BEGIN,"OPTIONS"},
   {_MAIN2,_BEGIN,"INFO LOGS"},
   {_MAIN3,_BEGIN,"DATE / TIME CLOCK"},
   {_SUBMENU_1A,_,"Heat Operating Mode"},
   {_SUBMENU_1AA,_SUBMENU_1A,"Preheat Mode"},
   {_SUBMENU_1AB,_SUBMENU_1A,"Hi Temp. Only Mode"},
   {_SUBMENU_1AC,_SUBMENU_1A,"Economy Mode"},
   {_SUBMENU_1B,_,"Hi Temp. Duration"},
   {_SUBMENU_1C,_,"Max NonStop Steam"},
   {_SUBMENU_1CA,_SUBMENU_1C,"Range"},
   {_SUBMENU_1CB,_SUBMENU_1C,"Mode ON/OFF"},
   {_SUBMENU_1D,_,"Stop Switch Override  "}, //22
   {_SUBMENU_1E,_,"Room Overheat Alarm"},
   {_SUBMENU_1EA,_SUBMENU_1E,"Temp. Range"},
   {_SUBMENU_1EB,_SUBMENU_1E,"Mode:Enable/Disable"},
   {_SUBMENU_1EC,_SUBMENU_1E,"Unit of Measure"},
   {_SUBMENU_1ED,_SUBMENU_1E,"Relay Switch NO/NC"},
   {_SUBMENU_1F,_,"Aux. Relay Switch"},
   {_SUBMENU_1FA,_SUBMENU_1F,"Normally Open/Close"},
   {_SUBMENU_1FB,_SUBMENU_1F,"Mode: ON/OFF"},
   {_SUBMENU_1G,_,"Water Fill Time"},
   {_SUBMENU_1GA,_SUBMENU_1G,"Time Between Fills"},
   {_SUBMENU_1GB,_SUBMENU_1G,"Fill Duration"},
   {_SUBMENU_1H,_,"Flush Parameters"},
   {_SUBMENU_1HA,_SUBMENU_1H,"Flush Duration"},
   {_SUBMENU_1HB,_SUBMENU_1H,"Flush Wait Time"},
   {_SUBMENU_1HC,_SUBMENU_1H,"Flush Quantity"},
   {_SUBMENU_1I,_,"Min. Contactor Cycle  "}, //22
   {_SUBMENU_1J,_,"Scent Pump Override"},
   {_SUBMENU_1K,_,"Keep Boiler Warm"},
   {_SUBMENU_1KA,_SUBMENU_1K,"Heat ON Time"},
   {_SUBMENU_1KB,_SUBMENU_1K,"Wait Time"},
   {_SUBMENU_1KC,_SUBMENU_1K,"Mode: ON/OFF"},
   {_SUBMENU_1L,_,"Save All?"},
   {_SUBMENU_2A,_MAIN2,"Error Codes"},
   {_SUBMENU_2B,_MAIN2,"Service Log"},
   {_SUBMENU_2C,_MAIN2,"Enable logging"},
   {_SUBMENU_3A,_MAIN3,"Time/Date Set"},
   {_SUBMENU_3B,_MAIN3,"Enable DST"}
Here is the functions I call:
printf(lcd_putc,"      %s",MenuGeneral[0].menuName); // no print out
void foo (void) {
unsigned int8 len_0, buff_0[20];
len_0=strlen(MenuGeneral[0].MenuName); // trim strings to 19
   for(i=0;i<19;i++) buff_0[i]=MenuPointer[0].MenuName[i];
   buff_0[19]='\0';
printf("\f%u  %s",len_0,buff_0);} // prints 0 for len_0 and nothing for buff_0
PostPosted: Mon Mar 12, 2018 7:58 pm     Reply with quote
I made the test program shown below, and got the mismatched pointer
types error.
I was able to get to work by casting the strlen parameter, as shown in
bold below:
#include <18F46K22.h>
#fuses INTRC_IO, NOWDT, BROWNOUT, PUT, NOPBADEN
#use delay(clock=4M)
#include <string.h>
} TypeMenu;
TypeMenu MenuGeneral[3];
void foo(void)
int8 i;
len_0 = strlen((unsigned int8 *)MenuGeneral[0].MenuName);
for(i=0; i<19; i++)
buff_0[i] = MenuPointer[0].MenuName[i];
buff_0[19]= '\0';
printf("\f%u %s", len_0, buff_0);
foo();
while(TRUE);
adcor
PostPosted: Mon Mar 12, 2018 9:56 pm     Reply with quote
Thank you, that cleared my errors but still my prints do not work, here what is happening. If I declare an array 3 elements of TypeMenu structure, (MenuPointer[3]) as in the code and have a const type as well:
const TypeMenu MenuGeneral[3]
   {_MAIN3,_BEGIN,"DATE / TIME CLOCK"};
and then:
MenuPointer[0]=MenuGeneral[0];
printf("\f MP=%s     MG=%s", MenuPointer[0].MenuName,MenuGeneral[0].MenuName);
There is no string printed for MenuPointer[0], only for MenuGeneral.
Now if I declare just one structure:
TypeMenu MenuPointer0;
&MenuPointer0=MenuGeneral[0]; // use of &
printf("\f MP=%s     MG=%s", MenuPointer0.MenuName,Menugeneral[0].MenuName);
it prints out for both strings. If I dereference the array as &MenuPointer[0] it does not work. Again this is happening with PIC24 only. I did not have to use attrib_packed or extra casting on a 18F4550. Thanks
PostPosted: Mon Mar 12, 2018 10:31 pm     Reply with quote
I have a question about your use of 'const' for the MenuGeneral array.
Do you want to use 'const' in the CCS sense of "store the array in flash
memory", or do you want to use it in the ANSI sense of putting the
array in RAM, but make it be read-only ?
adcor
PostPosted: Mon Mar 12, 2018 10:47 pm     Reply with quote
Just in RAM, read only. Thanks.
PostPosted: Mon Mar 12, 2018 11:17 pm     Reply with quote
Try adding this line after the #include line for your PIC.
#device ANSI
I don't guarantee it will solve all your problems, but you should try it.
With the 18F46K22, I found that if I used that line, and removed the
packed attribute, then it worked.
adcor
PostPosted: Mon Mar 12, 2018 11:58 pm     Reply with quote
Thanks for all your help, but it did not work, it created other dozens of errors throughout the code. For now I'll stick with PCH/PIC18, it seems much more reliable.
PostPosted: Tue Mar 13, 2018 4:14 am     Reply with quote
ANSI doesn't seem to force RAM for the CONST on PIC24's. Use:
#DEVICE CONST=READ_ONLY
Instead, which seems to work.
However there are some major caveats. When you use 'packed' things like INT16's, can be generated on byte boundaries. It will cause problems with all sorts of functions.
Does your menu really have to use a 23byte name?. If this was 22 or 24, then the whole structure would move back to being a word aligned variable, and you can get rid of packed.....
adcor
SOLVED : PIC24 pointer type do not match
PostPosted: Tue Mar 13, 2018 5:01 pm     Reply with quote
yeap, you nailed it. The size of menu array was increased to 24 and packed attribute was removed. With the use of #DEVICE CONST=READ_ONLY I got it working. Good lesson to keep data word aligned for these beasts. Thank you guys for all your support!
PostPosted: Wed Mar 14, 2018 2:11 am     Reply with quote
Yes. The only time you should really use 'packed', is if you are generating a structure that needs an alignment to work with something 'else' outside the chip. Then go back to word aligning for your own stuff inside....
Glad it is now working. Smile
