Posted: Fri Jan 12, 2018 8:49 am |
Moved from the code library (read the forum policy - line 2, for 'why').
However you are not off to a good start...
1) These forums are not 'solve it all for you' forums, they are for people to _help_ you with problems with writing your code. If you want a solution completely written, there are people who will do this, but the cost will be several hundred dollars a day...
2) There are a lot of different RFID interfaces. Different makes of tag have different features. Not all compatible. There are at least seven different frequency bands used by different types of tags, and different actual types of tags (particularly active or passive). A generic tag reader, would be much too complex to fit in a PIC16...
You need to start by actually specifying what you really want to do. |
