Extra clock cycle
russk2txb
Extra clock cycle
PostPosted: Fri Dec 22, 2017 9:56 am     Reply with quote
I am using a USB Master dev kit (18F67J10) to generate a fast clock. The clock must run for 68 microseconds. Here is the code:
....................   // set up timer 1 to interrupt in 68 us. At 40 Mhz, timer1 tick is .8 us, so it takes 85 ticks for 68 us.
....................   // T1 is a 16 bit timer so the preload value is 65536 - 85 = 65451
....................   set_timer1 (65451);
00E10:  SETF   FCF
00E12:  MOVLW  AB
00E14:  MOVWF  FCE
....................   gb68us = 0;
00E16:  MOVLB  3
00E18:  CLRF   xA2
....................   do {
....................      output_low (PIN_F4);
00E1A:  BCF    F97.4
00E1C:  BCF    F8E.4
....................      output_high (PIN_F4);
00E1E:  BCF    F97.4
00E20:  BSF    F8E.4
....................   while (gb68us == 0);
00E22:  MOVF   xA2,F
00E24:  BZ    0E1A
....................   disable_interrupts (int_timer1);
00E26:  BCF    F9D.0
The global variable gb68us is an int8 and is set to one by the timer1 interrupt handler.
It works very well except for one thing. After it is done, a single extra clock pulse is generated, 11 microseconds after the last normal cycle. Or it may be that the last pulse is delayed for 11 us. I set a breakpoint on the disable_interrupts line and the extra pulse is still generated (or delayed). I cannot figure out why.
Can anyone give me a clue as to what could cause this?
Thanks, Russ
PostPosted: Fri Dec 22, 2017 12:16 pm     Reply with quote
That's about the time it'd take to get into and out of the interrupt handler. Probably the delay....
Leave the interrupt disabled.
    clear_interrupts(INT_TIMER1);
    do
    while (!interrupt_active(INT_TIMER1));
Interrupts are _slow_. They give you a response, but not for a significant time. Testing the flag tells you when it triggers
A disabled interrupt can still set, it just can't call a handler.
russk2txb
PostPosted: Fri Dec 22, 2017 4:33 pm     Reply with quote
Thanks Ttelmah. You always have great answers. That worked just right. I am really not sure exactly how the interrupt delay got in the way of processing that last pulse on time, but it is obvious that it did. I had already tried not turning off the interrupt and it made no difference. But success is what is important here.
Thanks again, Russ
