Trouble with EXT INT
dhpl
PostPosted: Tue Nov 21, 2017 11:50 am     Reply with quote
I'm new to PIC.
I need 4 ext int for a project. A quick example as is follow, however I'm unable to make the ext int to work. The input pins are working as normal input (under main) however none of them is responding from interrupt.
Any help will be appreciated.
#include <16f877a.h>
#fuses HS,NOWDT,NOPROTECT,BROWNOUT,NOLVP,NOCPD
#use delay(clock = 20MHz)
//#use fast_io(b)
// LCD 2x16
#define LCD_DB7             PIN_D7
#define LCD_DB6             PIN_D6
#define LCD_DB5             PIN_D5
#define LCD_DB4             PIN_D4
#define LCD_RS              PIN_D3
#define LCD_RW              PIN_D2
#define LCD_E               PIN_D1
#include <flex_LCD.c>
#define BUTTON_A           PIN_B4
#define BUTTON_B           PIN_B5
#define BUTTON_C           PIN_B6
#define BUTTON_D           PIN_B7
int state = 0;
#INT_EXT
void btn_int() {
   if(input(BUTTON_A)) {
      state = 1;
   if(input(BUTTON_B)) {
      state = 2;
   if(input(BUTTON_C)) {
      state = 3;
   if(input(BUTTON_D)) {
      state = 4;
void main ()
   set_tris_b(0x1E);
   lcd_init();               // LCD start
   delay_ms(20);
   lcd_putc("\f");           // Clear the LCD
   ext_int_edge( L_TO_H );   // Sets up EXT
   enable_interrupts(INT_EXT);
   while(TRUE){
      lcd_gotoxy(1,2);
      switch(state) {
         case 1:
            printf(lcd_putc, "Action 1");
         case 2:
            printf(lcd_putc, "Action 2");
         case 3:
            printf(lcd_putc, "Action 3");
         case 4:
            printf(lcd_putc, "Action 4");
PostPosted: Tue Nov 21, 2017 12:21 pm     Reply with quote
INT_EXT, only works on pin B0.
The interrupt you are trying to use is the interrupt on change. INT_RB.
Interrupt on change triggers always on both edges (L_TO_H only applies to INT_EXT).
There is another problem in the approach.
If (for instance) B7 goes high, 'state' will equal 4. However another then triggers without this releasing, the interrupt will be called again, and it'll still return '4', ignoring the others that have triggered....
PostPosted: Tue Nov 21, 2017 2:29 pm     Reply with quote
I seem to recall that CCS has an 'how-to' in the FAQ section of the manual...
not on the eng pc so I can't look it up...
dhpl
PostPosted: Tue Nov 21, 2017 8:53 pm     Reply with quote
Many thanks for your reply.
I changed the interrupt to int_rb. Not much success.
Read a lot of how to, but couldn't figure out the rb approach. Shading more lights may help. Smile
PostPosted: Tue Nov 21, 2017 9:09 pm     Reply with quote
CCS has an example 'ex_pbutt.c' that may work for you...
there is another , I thought was in the FAQ section of the manual.. I KNOW it's 'somewhere' as I used it on an 877 years ago... it showed how in the ISR you read the port, decide which pin was active (RB4,RB5,RB6 or RB7).
PostPosted: Tue Nov 21, 2017 9:11 pm     Reply with quote
Look at this CCS examples file:
Ex_pbutt.c
It's in the Examples folder on your PC for CCS.
