Initialisation with PIC18f65j90
Beurk
PostPosted: Fri Nov 03, 2017 1:34 am     Reply with quote
Hi guys,
I have some issues with the configuration of my PIC18F65j90. I use this pic for drive a LCD screen in 1/4Mux and 1/3 Bias.
You can found the datasheet of the LCD screen right here : http://www.good-display.com/products_detail/productId=240.html
I have used the following steps for the initialisation of the PIC. On each I/O pins of the PIC, i have 1.25V DC.
//-----------------------------------Bit COnfiguration-----------------------------
// CONFIG1L
#pragma config WDTEN = ON       // Watchdog Timer Enable bit (WDT enabled)
#pragma config STVREN = ON      // Stack Overflow/Underflow Reset Enable bit (Reset on stack overflow/underflow enabled)
#pragma config XINST = OFF      // Extended Instruction Set Enable bit (Instruction set extension and Indexed Addressing mode disabled (Legacy mode))
// CONFIG1H
#pragma config CP0 = OFF        // Code Protection bit (Program memory is not code-protected)
// CONFIG2L
#pragma config FOSC2 = ON       // Default/Reset System Clock Select bit (Clock selected by FOSC1:FOSC0 as system clock is enabled when OSCCON<1:0> = 00)
#pragma config FOSC = HS        // Oscillator Selection bits (HS oscillator)
#pragma config FCMEN = OFF      // Fail-Safe Clock Monitor Enable bit (Fail-Safe Clock Monitor disabled)
#pragma config IESO = OFF       // Two-Speed Start-up (Internal/External Oscillator Switchover) Control bit (Two-Speed Start-up disabled)
// CONFIG2H
#pragma config WDTPS = 256   // Watchdog Timer Postscaler Select bits (1:256)
// CONFIG3L
// CONFIG3H
#pragma config CCP2MX = ALTERNATE// CCP2 MUX bit (CCP2 is multiplexed with RE7)
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
#include <xc.h>
Please any advice would help me. Thanks in advance.
Beurk-Switzerland
PostPosted: Fri Nov 03, 2017 1:50 am     Reply with quote
Are you using CCS C?.
This is a forum for CCS C, not other C's. Though CCS C can use the syntax you are showing, what you are posting is the core syntax for another C like Microchip C.
xc.h is the Microchip header file, not the CCS one.
You need to be going to the Microchip forum....
The command to configure the LCD in CCS, is 'setup_lcd'....
Beurk
PostPosted: Fri Nov 03, 2017 2:10 am     Reply with quote
ok thank you for your answer
