art
| Write Integer to EEPROM |
Posted: Wed Jul 26, 2017 2:19 am |
I need to write an integer 1234 to eeprom.
Suppose it should display 1234, but it will show 210.
I need help to solve this problem.
Here is my code.
#include <18F4550.h>
#fuses HSPLL,NOWDT,PROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN
#use delay(clock=48000000)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7,ERRORS)
#include <string.h>
#include <input.c>
#include <stdio.h>
#include <stdlib.h>
#include <usb_cdc.h>
#include <math.h>
#include "24256.c"
char c;
unsigned char d;
unsigned char key;
int32 data=1234;
usb_init_cs();
while (TRUE)
usb_task();
if (usb_cdc_kbhit())
c=usb_cdc_getc();
if (c=='\n') {putc('\r'); putc('\n');}
if (c=='\r') {putc('\r'); putc('\n');}
while(true)
d = usb_cdc_getc();
if(d=='C') // push C
while (key!=32) // push SPACE BAR to stop
if(usb_cdc_kbhit())
{key=usb_cdc_getc();}
init_ext_eeprom();
write_ext_eeprom(0, data);
read_ext_eeprom(0);
printf(usb_cdc_putc,"\r\nmSEC: %lu\r\n",(int16)read_ext_eeprom(0) );
} key=0; // to initialize 'key' not as SPACE BAR
Posted: Wed Jul 26, 2017 2:43 am |
write_eeprom, and read_eeprom, read _one byte_, to/from the EEPROM. That is what it says in the manual....
The functions to read/write larger types, are in the library 'internal_eeprom.c'.
write_int32_eeprom, and read_int32_eeprom |
Posted: Wed Jul 26, 2017 2:44 am |
Look in the CCS drivers directory for the external_eeprom.c file.
It has functions to read and write int32 variables to eeprom. |
Posted: Wed Jul 26, 2017 2:48 am |
| Apologies. Heading said 'EEPROM', not 'external EEPROM', so I assumed the internal EEPROM..... |
art
Posted: Wed Jul 26, 2017 3:29 am |
If I change to int32, it will compile with error --> Undefined identifier -- write_int32_ext_eeprom.
What should I do?
#include <string.h>
#include <input.c>
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
#include "24256.c"
char c;
unsigned char d;
unsigned char key;
int32 data=1234;
usb_init_cs();
while (TRUE)
usb_task();
c=usb_cdc_getc();
while(true)
d = usb_cdc_getc();
if(usb_cdc_kbhit())
init_ext_eeprom();
write_int32_ext_eeprom(0, data);
read_int32_ext_eeprom(0);
printf(usb_cdc_putc,"\r\nmSEC: %lu\r\n",read_int32_ext_eeprom(0) );
Posted: Wed Jul 26, 2017 3:52 am |
Art, when you add a driver file, you #include it, just like you've done with
all the other drivers near the start of your program. |
art
Posted: Wed Jul 26, 2017 3:58 pm |
Hi PCM,
I've just modified the code. I found out if i put #include <external_eeprom.c> , it will compile with many errors , however if write the code as below it can successfully compile. However i have not test it. Is it correct ?
#include <string.h>
#include <input.c>
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
#include "24256.c"
int8 i;
int16 data;
void write_int16_ext_eeprom(EEPROM_ADDRESS address, int16 data)
for(i = 0; i < 2; ++i)
write_ext_eeprom(address + i, *((int8 *)(&data) + i));
int16 read_int16_ext_eeprom(EEPROM_ADDRESS address)
*((int8 *)(&data) + i) = read_ext_eeprom(address + i);
return(data);
char c;
unsigned char d;
unsigned char key;
int16 data=1234;
usb_init_cs();
while (TRUE)
usb_task();
c=usb_cdc_getc();
while(true)
d = usb_cdc_getc();
if(usb_cdc_kbhit())
init_ext_eeprom();
write_int16_ext_eeprom(0, data);
read_int16_ext_eeprom(0);
printf(usb_cdc_putc,"\r\nmSEC: %lu\r\n",read_int16_ext_eeprom(0) );
Posted: Wed Jul 26, 2017 5:01 pm |
You have to put it below the 24256.c eeprom driver, as shown in bold
below. You will get some USB driver warnings, but those don't matter.
| Quote: |
#include <string.h>
#include <input.c>
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
#include "24256.c"
If you still get errors, then post the errors and your CCS compiler version. |
art
Posted: Wed Jul 26, 2017 6:51 pm |
Hai PCM
If i put #include<external_eeprom.c> before #include "24256.c". It will show errors when compile . If i put after it, it can compile without error. I have test the code and it works. It shows output 1234.
Thanks PCM |
Posted: Wed Jul 26, 2017 11:13 pm |
It's worth saying 'why'.
The 'driver' here is a set of code. It provides functions to read/write multiple bytes to EEPROM, _using the standard functions to read/write one byte to the EEPROM_.
The compiler reads things sequentially.
So the function to read/write one byte, needs to be prototyped or defined before the multi byte 'driver' can use them.
This is why the includes need to be before you use them.
First a comment.
You only need to init the EEPROM once at the start of the code.
Then a general question.
Why are you including math.h?.
Math.h is not needed for the normal arithmetic (+-*/ etc..). It is only needed for 'high level' maths (sin, code, exp etc.). Generally this maths is stuff that you should think very carefully before using in a microprocessor.
At the moment you are not using it, but 'beware' if you do. |
art
Posted: Thu Jul 27, 2017 1:40 am |
Dear ttelmah
Thanks for the explanation.
Actually, the original code is quite long and i forgot to delete the Math.h function. |
Posted: Thu Jul 27, 2017 4:14 am |
The comment about math.h still applies though...
You should think _very_ hard if there is a way not to use it. 99.9% of code can be done using a bit more ingenuity, and often saving a lot of size/time, without this. The few things that do 'need' high level maths are often better coded using perhaps a look up table, or slightly less accurate alternative functions.
In possibly several thousand projects, I've only used math.h on a PIC in perhaps less than 1% of them. |
oxo
Posted: Thu Jul 27, 2017 4:31 am |
| Ttelmah wrote: | | several thousand projects |
Superman. |
Posted: Thu Jul 27, 2017 4:44 am |
No, just been at it a _long_ time.... (There isn't a standard emoticon for something like a 'father time' figure).
When MicroChip posted a 'potted history' of the PIC, I had to point out to them that one of their dates was wrong, since I had been using a PIC before they said it had been released....
Also some things can be tiny. Just a chip to generate a particular timing etc..
If you are involved in perhaps ten big projects, and then a few dozen little things like this a year, and do it non stop for perhaps 40 years, it 'adds up'....
Many of the big things use larger processors, but less and less now, with the capabilities of the 16bit PIC's. |
