pilar
| How to declare an array char type in a function |
Posted: Wed Jul 12, 2017 6:14 pm |
Hi, I am trying unsuccessfully to declare an array char type in a function, can someone tell me what is my error?
| Code: | #include <18F4520.h>
#fuses HS,NOWDT,NOPROTECT,NOLVP,NOBROWNOUT,NOSTVREN
#use delay(clock=20MHz)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS)// RS232 Estándar
#include <stdlib.h>
#define LED PIN_D0
#define ON output_high
#define OFF output_low
int const maxLongBuffRX=42;
char bufferRX[maxLongBuffRX];
int indBufferRX=0x00;
char XCommand[maxLongBuffRX];
char flag_RptaCommand;
int i;
void Add_bufferRX(char c);
#int_rda
void serial_isr() {
if(kbhit()){
Add_bufferRX(getc());
flag_RptaCommand = 1;
void Ini_buff_rec(void){
int i;
for(i=0;i<maxLongBuffRX;i++){
bufferRX[i]=0x00;
indBufferRX=0x00;
void Add_bufferRX(char c){
switch(c){
case 0x0D:
case 0x0A:
default:
bufferRX[indBufferRX++]=c;
int1 SendATCommand( char CommandTX[], char RXCommand[] ){
Ini_buff_rec();
for (i=0; i<strlen(strlen(XCommand)); i++){
printf ("%c",CommandTX[i]);
while ( flag_RptaCommand == 0);
strcpy( XCommand,RXCommand);
if(strncmp(bufferRX,XCommand,strlen(XCommand)))
return(1);
return(0);
void main(){
OFF(LED);
if (SendATCommand("AT", "OK")){
ON(LED);
delay_ms(200);
while (TRUE);
Posted: Wed Jul 12, 2017 7:31 pm |
Add the line shown in bold below:
| Quote: | #include <18F4520.h>
#device PASS_STRINGS=IN_RAM
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS)// RS232 Estándar |
It should now compile OK. |
