Adafruit BNO055 Absolute Orientation Sensor
gjs_rsdi
PostPosted: Mon May 01, 2017 8:55 pm     Reply with quote
Hi
Have some forum members that used this sensor?
I try to find the I2C protocol in HEX/Binary as for other sensors and EEPROM's but can't.
Best wishes
Joe
PostPosted: Mon May 01, 2017 11:09 pm     Reply with quote
ADR:
Set this pin high to change the default I2C address for the BNO055 if you
need to connect two ICs on the same I2C bus. The default address is
0x28
. If this pin is connected to 3V, the address will be 0x29.
To convert the 0x28 address to CCS format, multiply it by 2, and you
get 0x50. Use the i2c bus scanner in the Code Library to confirm this.
The above quote is from the "Other Pins" section on page 8:
https://cdn-learn.adafruit.com/downloads/pdf/adafruit-bno055-absolute-orientation-sensor.pdf
gjs_rsdi
PostPosted: Mon May 01, 2017 11:50 pm     Reply with quote
Thank you for the answer PCM programmer.
What I mean is the I2C protocol, but I find it in the Bosch datasheet.
Best wishes
Joe
