18F46K22 #INT_RDA2 not triggering [SOLVED]
maxrate
PostPosted: Fri Apr 21, 2017 5:55 pm     Reply with quote
Hi everyone,
I can't seem to crack this. Running version 5.071, 18F46K22 and I've tried numerous development boards. It seems I am able to capture #INT_RDA interrupts, but not #INT_RDA2 interrupts. All 5 volt operation. Tried different crystal speeds and other boards that use oscillators.
I've built a simple program using CCS project wizard to illustrate. The operation is simple, if a byte is received on UART1, RB1 LED will toggle on/off per character -- same operation for UART2, but RB2 toggles on and off - Trouble is, UART2 / #INT_RDA2 do not seem to work.
There have been some helpful posts in the forum, however I am still struggling with this unfortunately.
I have confirmed that UART1 uses PINs RC7/RC6, and UART2 uses PINs RB7/RB6. Knowing that the ICD uses RB7/RB6, I have disconnected the programmer while doing my character tests. I am using different sources of serial data; GPS module, and a simple PC RS232 to TTL handy dandy module.
UART1 toggles the LED fine, UART2 doesn't do anything.
Below is the code;
MAIN.C
#include <main.h>
#INT_RDA
void  RDA_isr(void)
   output_toggle(SERIAL_LED_1);
   c=fgetc(PORT1);
#INT_RDA2
void  RDA2_isr(void)
   output_toggle(SERIAL_LED_2);
   c=fgetc(PORT2);
   enable_interrupts(INT_RDA);
   enable_interrupts(INT_RDA2);
      //Example blinking LED program
      output_low(LED);
      delay_ms(DELAY);
      output_high(LED);
      delay_ms(DELAY);
      //TODO: User Code
MAIN.H
#include <18F46K22.h>
#device ADC=10
#FUSES NOPBADEN                 //PORTB pins are configured as digital I/O on RESET
#use delay(crystal=25MHz)
#use rs232(baud=9600,parity=N,UART1,bits=8,stream=PORT1)
#use rs232(baud=9600,parity=N,UART2,bits=8,stream=PORT2)
#define LED PIN_B0
#define SERIAL_LED_1 PIN_B1
#define SERIAL_LED_2 PIN_B2
#define DELAY 50
char c; // temporary serial character buffer
PostPosted: Fri Apr 21, 2017 7:23 pm     Reply with quote
#device ADC=10
Are you actually using a 25 MHz crystal on the board ?
According to Table 27-7,
TABLE 27-7: EXTERNAL CLOCK TIMING REQUIREMENTS
For HS mode, the maximum crystal frequency allowed is 20 MHz.
See page 436 in the 18F46K22 data sheet:
http://ww1.microchip.com/downloads/en/DeviceDoc/40001412G.pdf
maxrate
PostPosted: Fri Apr 21, 2017 7:37 pm     Reply with quote
Hello PCM Programmer - thank you for your reply.
I am using a 25 Mhz crystal, I have tried 4 Mhz crystals as well (and other dev boards). Because of your suggestion, I've just installed a 12 Mhz crystal, recompiled and tested - same result unfortunately.
I wanted to add that with my testing, I am sending only a few characters (keystrokes mostly) as my data source, and I am not sending characters to the two UARTS simultaneously. I am trying one at a time, very basic testing.
Still a mystery to me. I strongly feel I've covered all of the basics. I've tried other dev boards, oscillators, crystals, different PIC18F46K22 chips, different sources of serial data, different baud rates (down to 2400 baud), unplugging the ICD programmer.
PostPosted: Fri Apr 21, 2017 7:50 pm     Reply with quote
What pins are you using for UART2 on the 18F46K22 ?
What chip package does your board have for the 18F46K22 ?
maxrate
PostPosted: Fri Apr 21, 2017 7:51 pm     Reply with quote
Shocked
I've determined what I've been doing wrong. When consulting the datasheet (http://ww1.microchip.com/downloads/en/DeviceDoc/40001412G.pdf) I had been referencing the wrong "pin summary" table. I was viewing the table on page 6 - I should have been viewing page 7. I have my PINs mixed up as a result. The 2nd UART on a 18F46K22 are available on PINs RD7/RD6, NOT RB7/RB6.
Thank you for all who have viewed my post. I feel better now Very Happy
maxrate
PostPosted: Fri Apr 21, 2017 7:53 pm     Reply with quote
Hello PCM Programmer - I just posted same time you posted. You were spot on in asking what PINs. I've been at this on and off all day. Seems your original suggestion/reference about the datasheet for HS operation/crystal speed triggered a thought on my end here that I should re-check the datasheet. I'm glad I did. Thank you again.
