List index out of bounds [Solved]
Aileyus
PostPosted: Fri Mar 24, 2017 10:37 am     Reply with quote
I get this message when I try to add my struct variable to the watch window.
I'm trying to look at anything in the sample_data struct. I've tried sample_data and sample_data.temp. The watch window doesn't like my struct but the compiler sees no problem.
Thanks in advance.
I'm using the PIC16F1825 Development Kit.
My code is as follows:
#include <ADC.h>
#define ANALOG PIN_A4
struct data_struct
   unsigned int16 current;
   unsigned int16 max_current;
   unsigned int16 temp;
   unsigned int16 max_temp;
} sample_data;
   setup_adc_ports(sAN3);
// Will change channels in the final product.
      set_adc_channel(3);
      delay_ms (1);
      sample_data.temp = read_adc();
      delay_ms (1);
      set_adc_channel(3);
      delay_ms (1);
      sample_data.current = read_adc();
      if (sample_data.temp > sample_data.max_temp)
         sample_data.max_temp = sample_data.temp;
      if (sample_data.current > sample_data.max_current)
         sample_data.max_current = sample_data.current;
      //TODO: User Code
Aileyus
PostPosted: Fri Mar 24, 2017 12:19 pm     Reply with quote
Never mind. I found it. It turned out to be some hangup between Windows 10 and/or CCS Compiler. I shut down and restarted and I can now use the watch window.
