		| Author | Message |
		| Mark DSylva Guest
				| looking for h/w i2c master example |
				|  Posted: Tue Jan 07, 2003 4:18 pm |   |
				| Hi, I'm looking for an example which uses the h/w I2C in master mode.  I wrote some code and expected to see some activity on the SCLK and SDATA lines but the they are always high.
 Mark
 ___________________________
 Original Post ID: 10519
		| PCM programmer
				| Re: looking for h/w i2c master example |
				|  Posted: Tue Jan 07, 2003 5:14 pm |   |
				| :=Hi, :=I'm looking for an example which uses the h/w I2C in master mode.  I wrote some code and expected to see some activity on the SCLK and SDATA lines but the they are always high.
 1. What version of the compiler do you have ?
 2. What PIC do you have ?
 Those are the first two things to check when H/W i2c doesn't
 work.
 Here is a previous post, regarding the compiler version issue:
 <a href="http://www.pic-c.com/forum/general/posts/10231.html" TARGET="_blank">http://www.pic-c.com/forum/general/posts/10231.html</a>
 Here is a post, regarding the type of PIC that you're using:
 <a href="http://www.pic-c.com/forum/general/posts/8499.html" TARGET="_blank">http://www.pic-c.com/forum/general/posts/8499.html</a>
 Assuming that your version of the compiler supports it,
 here is a test program.  You will have to un-comment
 the line that enables H/W i2c, and comment out the line
 for software i2c.
 <a href="http://www.pic-c.com/forum/general/posts/8281.html" TARGET="_blank">http://www.pic-c.com/forum/general/posts/8281.html</a>
 If your version of the compiler doesn't support H/W i2c
 then this program can be used:
 <a href="http://www.pic-c.com/forum/old/messages/725.html" TARGET="_blank">http://www.pic-c.com/forum/old/messages/725.html</a>
 Original Post ID: 10521
		| Mark DSylva Guest
				|  Posted: Tue Jan 07, 2003 9:00 pm |   |
				| :=:=Hi, :=:=I'm looking for an example which uses the h/w I2C in master mode.  I wrote some code and expected to see some activity on the SCLK and SDATA lines but the they are always high.
 :=1. What version of the compiler do you have ?
 The version is quite recent : 3.130
 :=2. What PIC do you have ?
 I am using a PIC 18F452 and an ICE2000 emulator.
 I'm going to try your suggestion and report back if I have success or not.
 Mark
 :=Those are the first two things to check when H/W i2c doesn't
 :=work.
 :=Here is a previous post, regarding the compiler version issue:
 := <a href="http://www.pic-c.com/forum/general/posts/10231.html" TARGET="_blank"> <a href="http://www.pic-c.com/forum/general/posts/10231.html" TARGET="_blank">http://www.pic-c.com/forum/general/posts/10231.html</a></a>
 :=Here is a post, regarding the type of PIC that you're using:
 := <a href="http://www.pic-c.com/forum/general/posts/8499.html" TARGET="_blank"> <a href="http://www.pic-c.com/forum/general/posts/8499.html" TARGET="_blank">http://www.pic-c.com/forum/general/posts/8499.html</a></a>
 :=Assuming that your version of the compiler supports it,
 :=here is a test program.  You will have to un-comment
 :=the line that enables H/W i2c, and comment out the line
 :=for software i2c.
 := <a href="http://www.pic-c.com/forum/general/posts/8281.html" TARGET="_blank"> <a href="http://www.pic-c.com/forum/general/posts/8281.html" TARGET="_blank">http://www.pic-c.com/forum/general/posts/8281.html</a></a>
 :=If your version of the compiler doesn't support H/W i2c
 :=then this program can be used:
 := <a href="http://www.pic-c.com/forum/old/messages/725.html" TARGET="_blank"> <a href="http://www.pic-c.com/forum/old/messages/725.html" TARGET="_blank">http://www.pic-c.com/forum/old/messages/725.html</a></a>
 Original Post ID: 10527
 | You cannot post new topics in this forum You cannot reply to topics in this forum
