matthewsachs
| Loading 2 HEX files at once |
Posted: Sat Dec 10, 2016 10:20 am |
I'm using a bootloader to load my main program over USB.
Currently, I use CCSLoad + ICD-U64 to program the PIC with the bootloader hex file (let's call it B.hex). I then open up SIOW in order to load the main application (let's call it A.hex)
Everything works well, but it takes forever.
Is there any way to combine the B.hex and A.hex files into a single HEX file that CCSLoad can program the PIC with in one shot?
Some notes:
1. Both A.hex and B.hex have a link to this include file:
| Code: | #define LOADER_END 0x7FF
#define LOADER_SIZE 0x4FF
#ifndef _bootloader
#build(reset=LOADER_END+1, interrupt=LOADER_END+9)
#org 0, LOADER_END {}
#endif |
2. My bootloader code has this directive to pull in serial numbers from a text file stored in the same folder:
| Code: | | #serialize(dataee=0x02,binary=4,listfile="serial_source.txt",log="serial_log.txt") |
3. Here is a listing of my actual bootloader.hex
| Code: | :0400000020EF00F0FD
:0800080004EF04F00000000009
:0E00100000000000000000000CEF04F01000E3
:10004000F86AD09EC150C00B0F09C16E070EB46E86
:100050006BD97AD9F250006EF29EAA6A080EA96E88
:10006000DD0EA86EA69CA69EA6840F01550EA76E57
:10007000AA0EA76EA682A6B2FED7A6940050F212D0
:10008000928880B80ED0F2CF4FF0F29EAA6A090E85
:10009000A96EA69CA69EA680A8504FBEF28EAA0866
:0E00A00003E100012DD90F010001AADB0300CE
:0403000023D91200EB
:06030A00846B969C8D9CA3
:1003100000D0956883CF84F000D0969C8D8CFF0E22
:10032000956E84C001F01200826B968AFF0E956E66
:10033000969C8D8C969E8D8E826B823D01D003D0D3
:10034000E4DF822BFAD71200230E486EA60E476E0A
:100350000E0E4A6ED90E496EA10E4C6ED10E4B6E2A
:100360002C0E4E6E600E4D6E1200969C8D8C969EDD
:100370008D8E968884B80DD0956A82C08CFF00D08F
:10038000969E8D8E00D0969E8D9E00D0FF0E956E0F
:1003900001D000001200886B896B895101082BE3A2
:1003A00087C003F086C0E9FF87C0EAFFEF5040082E
:1003B00010E28851100DF3CF8AF087C003F086C099
:1003C000E9FF87C0EAFFEF508A25BF0F0A0F886F49
:1003D0000CD08851100DF3CF8AF086C0E9FF87C09A
:1003E000EAFFEF508A25D00F886F8951892B862B21
:1003F000D8B4872BD2D788C001F012004934026EDE
:100400004A34036E023603360236033602360336AA
:1004100002360336E00E021602504918826F03506E
:100420004A18836F4CC04AF04BC049F04EC04CF0A4
:100430004DC04BF048C04EF047C04DF0D890036A15
:100440004830026E4718846F03504818856F8251F8
:10045000841B8351851B8331036E8231026E03320C
:10046000023203320232033202320F0E03160250FE
:100470008419476E03508519486E47C001F0120079
:10048000876B8439876F0F0E87178751090809E238
:1004900085C0E9FF86C0EAFF410E8725F60FEF6EA3
:1004A00007D085C0E9FF86C0EAFF300E8725EF6ED2
:1004B00084510F0B876F875109080BE2010E8525C8
:1004C000E96E000E8621EA6E410E8725F60FEF6E6B
:1004D00009D0010E8525E96E000E8621EA6E300EE8
:1004E0008725EF6E1200F250036EF29EA68EA68450
:1004F0000F01550EA76EAA0EA76EA682000003502C
:10050000F21200011200D08CA69CF6503F0B006E38
:10051000C00EF6160A0082C001F0006607D0EECFCA
:10052000F5FF015204E00F00010603D000060B00A6
:100530000C003F0EF6143F0AF0E1A688D4DFD3DFAB
:100540000166EBD7F86A12004F92556A546A5D6AE9
:100550005C6A5B6A5A6AE8DEF7DE760E826F05DF58
:10056000310E826F02DF4FB224D14F80066A968629
:1005700084A602D00000FBD7036A0650070F016E65
:10058000000E032201C082F003C083F0BEDE83C0F0
:10059000EAFF82C0E9FF01C0EFFF0650062A036AA6
:1005A000070FE96E000E0320EA6EEF500D0803E01E
:1005B00006503F08DCE2130E826FD7DE07507C083E
:1005C00030E1010E5F6E010E065C5F5C28E2036A9B
:1005D0005F50070F016E000E032201C082F003C0BE
:1005E00083F003C087F001C086F0D5DE01C081F042
:1005F00005DF0150811B036A5F50070F016E000E7B
:10060000032201C082F003C083F081C084F003C0E4
:1006100086F001C085F034DF020E5F26D4D73A0E93
:10062000076E07503A08D8A4BBD0876B080E866FB8
:10063000B2DE01C060F0876B0A0E866FACDE01C0CF
:1006400082F0876B0C0E866FA6DE82C053F001C06D
:1006500052F0876B0E0E866F9EDE01C051F054C0C3
:1006600058F055C059F052C056F053C057F0512CB5
:1006700002D04F8295D0595205E1585203E15750AC
:10068000020808E2595206E1585204E1575007089F
:10069000D8B086D05952D8A483D058502F08D8A0AB
:1006A0007FD0506A010E5F6E030E065C5F5C14E241
:1006B000036A5F50070F016E000E032201C082F033
:1006C00003C083F003C087F001C086F064DE0150F0
:1006D0005026020E5F26E8D7FF0ED8805054010F37
:1006E000506E030E065C036A070F016E000E0322B4
:1006F00001C082F003C083F003C087F001C086F020
:100700004ADE0150505C02E04F904AD0515237E12E
:10071000090E5F6E5E6A030E065C5F5C23E25E504C
:100720005E2A036A610F016E000E032201C082F08F
:1007300003C083F0036A5F50070F016E000E0322AF
:1007400001C084F003C085F003C087F001C086F0CB
:1007500022DE83C0EAFF82C0E9FF01C0EFFF020E84
:100760005F26D9D758C0F8FF57C0F7FF56C0F6FF2D
:10077000EA6A610EE96E60C082F0C5DE11D05150A8
:1007800004080EE1876B100E866F05DE01C082F053
:10079000876B120E866FFFDD82C055F001C054F0EA
:1007A0004FA003D0060E826FE0DD110E826FDDDDFB
:1007B000DAD6060E826FD9DD110E826FD6DD1200F9
:04080000FFD712000C
:020000040030CA
:0E00000000C5061E0305B1000080FFE0FF40B2
:00000001FF |
Posted: Sat Dec 10, 2016 11:33 am |
Has been answered here many times. A search would find some answers.
Try:
<http://www.ccsinfo.com/forum/viewtopic.php?t=55676&highlight=import> |
Use the forum's search engine to search for this:
| Quote: | | combine* files bootloader |
Set it to "Search for all terms".
http://www.ccsinfo.com/forum/search.php
You'll find several threads on the topic. |
