PIC16LF1705 and DAC output
starfire151
PostPosted: Sun Jun 19, 2016 10:22 am     Reply with quote
I'm using PCWHD V5.044 on a Windows 10 machine.
I'm trying to get the DAC output for a PIC16LF1705 chip working in a test configuration.
I have the statement setup_dac(DAC_VDD | DAC_OUTPUT) in my startup code. I am attempting to write to the DAC output with a command dac_write(dacVal), where dacVal is an unsigned 8-bit value to be written to the DAC output.
I get a compiler error stating setup_dac and dac_write are undefined identifiers. I looked in the 16LF1705.h file and saw nothing about DAC setup.
According to the chip datasheet, there should be a DAC output available on pin A0.
Has anyone gotten this chip to work with the DAC output?
PostPosted: Sun Jun 19, 2016 11:12 am     Reply with quote
Your old version doesn't support it. You will have to write your own
routines. Something like this:
#include <16LF1705.h>
#fuses INTRC_IO, NOWDT
#use delay(clock=4M)
// Constants used in setup_dac() are:
#define DAC_OFF  0
#define DAC_VSS_VDD   0x80
#define DAC_VREF_VDD  0x81
#define DAC_VSS_VREF  0x84
#define DAC_VREF_VREF 0x85
#define DAC_VSS_FVR   0x88
#define DAC_VREF_FVR  0x89
// The following may be OR'ed in with the above using |
#define DAC_OUTPUT2   0x10
#define DAC_OUTPUT    0x20
#byte DAC1CON0 = 0x118
#byte DAC1CON1 = 0x119
void setup_dac(int8 value)
DAC1CON0 = value;
void dac_write(int8 data)
DAC1CON1 = data;
setup_dac(DAC_VSS_VDD | DAC_OUTPUT);
dac_write(128);
while(TRUE);
starfire151
PostPosted: Sun Jun 19, 2016 11:43 am     Reply with quote
Thanks very much!
