		| View previous topic :: View next topic   |
			vineel
				| Help to fix this error undefined identifier Motor_M1_On |
				 Posted: Tue Apr 19, 2016 3:57 am     |
				Hi! i am writing a code for joystick based wheel chair, using pic16f73.
Everything is fine, but i am getting a set of errors such as undefined identifiers Motor_M1_On, etc., which are related to dc motor.
My code is as follows:
#include <16F73.h>
#include <stdlib.h>
#include <Motor.h>
#fuses HS, NOWDT, BROWNOUT, PROTECT, PUT
#use delay(oscillator=20M)
unsigned long duty = 0;
void dowork(unsigned int x)
   switch(x)
    case 116:
            if(!input(pin_A0))
             set_pwm1_duty(700);
             set_pwm2_duty(700);
             Motor_M1_On(150,1); //1=forward, 0=reverse
             Motor_M2_On(150,1); //1=forward, 0=reverse
    case 117:
             set_pwm1_duty(700);
             set_pwm2_duty(700);
             Motor_M1_On(150,0); //1=forward, 0=reverse
             Motor_M2_On(150,0); //1=forward, 0=reverse
    case 51:
             Set_pwm1_duty(550); //fixed duty for turnings
             Set_pwm2_duty(550); //fixed duty for turnings
             output_high(PIN_C5);
             Motor_M1_On(100,0); //1=forward, 0=reverse
             Motor_M2 On(100,1); //1=forward, 0=reverse
    case 52:
             set_pwm1_duty(550);  //fixed duty for turnings
             set_pwm2_duty(550);  //fixed duty for turnings
             output_high(PIN_C6);
             Motor_M1_On(100,1); //1=forward, 0=reverse
             Motor_M2_On(100,0); //1=forward, 0=reverse
void Motor_M1(int direction)
      delay_ms(10);
      if(direction == 1) //Forward
         output_low(PIN_C0);
      if(direction == 0) //Reverse
         output_low(PIN_C1);
void Motor_M2(int direction)
         output_low(PIN_C0);
         output_low(PIN_C1);
   unsigned long int x=0;
   unsigned long int y=0;
   //Microcontroller Health Check
   output_low(PIN_C5);
   output_low(PIN_C6);
   output_low(PIN_C5);
   output_low(PIN_C6);
   setup_adc(ADC_CLOCK_INTERNAL);   //enables the a/d module
   setup_adc_ports(ALL_ANALOG);   //sets all the adc pins to analog
   //PWM Settings
    setup_timer_2(T2_DIV_BY_16, 127, 1);
    setup_ccp1(CCP_PWM);
    set_pwm1_duty(620);
    setup_ccp2(CCP_PWM);    //pwm setting for motor 2
    set_pwm2_duty(620);
      set_adc_channel(1);
      delay_ms(1);
      y = read_adc();
      delay_ms(1);
      set_adc_channel(0);
      delay_ms(1);
      x = read_adc();
      delay_ms(1);
      set_pwm1_duty(600);
      set_pwm2_duty(600);
      if(y < 80)
          output_high(PIN_C5); //LED on
          Motor_M1(0);
          Motor_M2(0);
      else if(y > 100)
          Motor_M1(1);
          Motor_M2(1);
      else if(x < 80)
            Motor_M1(1);
            Motor_M2(0);
      else if(x > 100)
            Motor_M1(0);
            Motor_M2(1);
     set_pwm1_duty(0);
     set_pwm2_duty(0);
     output_low(PIN_C5);
     output_low(PIN_C6);
Can anyone help me to fix this and suggest me right header file for dc motor control ? _________________ vineel |
			RF_Developer
				 Posted: Tue Apr 19, 2016 4:36 am     |
				At this simple level, with only a few routines, I'd suggest not using a header file at all.
The errors you describe are because the do-work routine calls routines that are not defined/declared. But that's no more than the error message says so that should nto be a surprise.
It doesn't matter that you don't call do_work() anywhere; if it's there at all, the routines it calls, such as Motor_M1_On and Motor_M2_On, have to be defined somewhere and they aren't.
It sounds as if you are confused over basic C code structure: how, why and where routines are defined. For that you need to read a C language book or tutorial. |
			vineel
				 Posted: Tue Apr 19, 2016 4:48 am     |
				 	  | RF_Developer wrote: | 	 		  At this simple level, with only a few routines, I'd suggest not using a header file at all.
So do i need to define the motors m1 and m2 ? I don't have much time to work on it, and for going through books and tutorial and by the way i'm newbie. Would you be kind enough to help me with this ? I mean can you provide me small sample so that i can understand ? Anyway thanks for your help bro. _________________ vineel |
			RF_Developer
				 Posted: Tue Apr 19, 2016 5:23 am     |
				 	  | Quote: | 	 		  | by the way i'm newbie |
That's blatantly obvious. It's also obvious, from the formatting, that the code you posted is cut and pasted from at least two sources. The PIC you are using is one of the very earliest flash-based parts, and has been effectively obsolete for many years, but is still used occasionally for teaching purposes.
To get rid of the errors, delete the do_work routine. There may well be some errors, different to the ones you've reported, but the one's you've reported will be gone.
There are severla problems with your code, including but by no means limited to the ADC set-up. Hint: ADC_CLOCK_INTERNAL is not recommended except under very specific circumstances.
I'd expect any practical wheelchair controller to give fully proportional control, most likely by a PID loop, probably with some sort of creep/nudge capability, all of which is fully safety interlocked.
So, all that considered, this is a late college assignment, isn't it? |
