nailuy
| UART from CPU and Hyper terminal not working right. |
Posted: Fri Apr 01, 2016 3:08 pm |
Hy.
I try to show on display the ascii code or simple character pressed on keyboard.
Program used is Hyper Terminal.
| Code: | #use delay(internal=1MHz)//,restart_wdt)
#use rs232(baud=2400, parity=N, xmit=PIN_C7, rcv=PIN_C6, bits=8, ERRORS)
if(kbhit()) {
x=kbd_getc();}
LCD_DATA_3=133;
printf(LCD_SEND_C,"%ld",x); |
Someone can help me to make this code work?
Thank you! |
Joined: 01 Jul 2010 Posts: 9630 Location: Greensville,Ontario
Posted: Fri Apr 01, 2016 4:08 pm |
What you've posted is NOT a complete program and we don't know what PIC or other hardware your using.
Basic PIC101.... we need a complete program, confirmation that a 1Hz LED program functions properly and what interface to PC you have. Also you appear to have an LCD module,so what driver are you using for that device.
We need a LOT more information before we can say it's 'this' or 'that' as to waht you're doing wrong.
Posted: Fri Apr 01, 2016 4:15 pm |
| Quote: |
You are using the printf format string to display a decimal number.
You want to display a character.
Download the CCS manual:
Go to the printf section and look at the available format strings. One of
them is for printing characters. Use it instead of %ld. |
nailuy
Posted: Sat Apr 02, 2016 10:56 am |
| Code: | while(TRUE)
delay_ms (100);
lcd_init_1();
delay_ms (500);
if(kbhit()) {
x=kbd_getc();}
LCD_DATA_3=133;
printf("\r\n Test");
in header is:
| Code: | #include <16F1788.h>
#device ADC=16
#FUSES PUT //Power Up Timer
#FUSES NOWDT
#FUSES PROTECT //Code protected from reads
#FUSES CPD //Data EEPROM Code Protected
#FUSES BROWNOUT_NOSL //Brownout enabled during operation, disabled during SLEEP
#FUSES NOCLKOUT //I/O function on OSC2
#FUSES WRT //Program Memory Write Protected
#FUSES NOVCAP //VCAP pin disabled
//#FUSES BORV19 //Brownout reset at 1.9V
#FUSES LPBOR //Low-Power Brownout reset is enabled
#use rs232(baud=2400, parity=N, xmit=PIN_C7, rcv=PIN_C6, bits=8, ERRORS)//, stream=PORT1, restart_wdt)
//#define int64 long long
#define LCD_DAT4 PIN_B5 //
#define LCD_DAT5 PIN_B4 //
#define LCD_DAT6 PIN_C5 //B7 / C5
#define LCD_DAT7 PIN_C4 //B6 / C4
#define LCD_E PIN_A1
#define LCD_RS PIN_A0
static unsigned int16 X; |
this are code used by me.
Can you help me?
Posted: Sat Apr 02, 2016 11:44 am |
please use code[] button when posting code....
1) do NOT enable the 'protect' fuse unless you're delivering product to client.
2) do NOT use 'restart_wdt' in #use RS232() or elsewhere unless you're code is 100% working WITHOUT it.
3) you define LCD pins, lcd_init_1() function but do not show the LCD driver.....
4) have to ask why just 1 MHz clock speed ?
nailuy
Posted: Sat Apr 02, 2016 12:43 pm |
Thank you
LCD_init_1 is initiate for my LCD with my header.
LCD have no problem is working.
problem is from if(kbhit())
show on display only when i close connection, so is not normal.
How to have X=getc()?
Nailuy |
Posted: Sat Apr 02, 2016 1:47 pm |
this line...
x=kbd_getc();}
means you have a keyboard device AND a driver for it, but you do not have that shown in your program
it's a similar problem with your LCD code. You call LCD functions but never show where they are loaded into your program.
My conclusion is that you are 'cut and pasting' bits of your code and NOT showing us the complete program as it cannot work as you've posted.
I cannot help any further without seeing your real program.
nailuy
Posted: Sun Apr 03, 2016 12:16 am |
Dear Temtronic.
LCD is one header and have no problem with him.
kbd_getc()
I make search on forum and I found... behind I do not have any code. That's why is not working probably.
I need your help to understand how to use or how to build code.
getc()
is simple command to get data from hyper terminal, is working when I close connection, and show last keyboard pressed sometime.
Thank you.
Nailuy. |
Posted: Sun Apr 03, 2016 5:19 am |
getc() is in the CCS manual. Press F11 with your project open and the CCS manual magically 'pops up'. I usually keep it open and minimized to quickly access it for obvious reasons!
CCS also kindly supplies LOTS of example programs that use getc() in additon to a good fact sheet on how to use it, in the manual.
kbd_getc() is a derivation of getc(), created to get a character from a keyboard. How it is used depends on the user's choice of keyboard,PIC /KBD interface and requirements for translation.
If you do NOT have a keyboard or keypad do NOT use kbd_getc() !
nailuy
Posted: Sun Apr 10, 2016 1:30 pm |
Hi Temtronic.
I made special code only for test.
In main is:
| Code: | #include <16F1788_test.h>
VAR1=356;
T3++;
if (T3==1000){ //65535
T3=0;
putc('\n');
putc('\r');
printf("%Lu",VAR1);
if(kbhit()) {
KEY2=getc();}
putc('\n');
putc('\r');
printf("%ld",KEY2);
and in header:
#device ADC=16
//#FUSES MCLR //Master Clear pin enabled
#FUSES NOMCLR
#FUSES NOLPBOR //Low-Power Brownout reset is disabled
#use delay(internal=1MHz,restart_wdt)
#use rs232(baud=2400,parity=N,xmit=PIN_C7,rcv=PIN_C6,bits=8,stream=P1)
static unsigned int16 VAR1; //
#locate VAR1 = 0x070
static unsigned int16 KEY2; //
#locate KEY2 = 0x072
static unsigned int16 T3; //
#locate T3 = 0x074 |
Are working:
VAR1 is sending by serial hex values:
0A 0D 33 35 36 0A 0D 30 and is repeating... so is okay all.
all are fine as ASCII code.
T3 is indexing
Are not working:
KEY2 every value sent as hex or char are as zeo received back
| Code: | if(kbhit()) {
KEY2=getc();} |
how can I make this work?
best regards. |
Posted: Mon Apr 11, 2016 3:04 pm |
First try a simple program to see if everything works. This program
echoes anything it receives back to the PC. Try it. Do you see what
you type in the terminal program window ?
#fuses INTRC_IO, NOWDT
#use delay(clock=1M)
#use rs232(baud=2400, UART1, ERRORS)
int8 value;
if(kbhit()) // Was a key pressed on PC keyboard ?
value = getc(); // If so, get it from UART
putc(value); // Then send it back to terminal program
nailuy
Posted: Tue Apr 12, 2016 10:55 am |
Dear PCM programmer
Thank you.
I make some changes:
I don't have pull up for MCLR externally so I set it to be internally.
Code not works and I changed to send continuously data and still not working.
So code:
| Code: | #include <16F1788_test2.h>
int8 value;
putc(8); // I put this row to see which pin is TX from UART
// if(kbhit()) // Was a key pressed on PC keyboard ?
// value = getc(); // If so, get it from UART
// putc(value); // Then send it back to terminal program
#FUSES NOMCLR
I look at pins B7, B6, C7 and C6 none of them transmit data.
But my program transmit data in okay mode...
so? |
ezflyr
Posted: Tue Apr 12, 2016 1:34 pm |
On that PIC, the Rx pin is RC7, and the Tx pin is RC6. This is 'UART1'. The other pins, RB7 & RB6 are an alternate set of pins for the UART, but they should not be active in your situation.
Now, the UART can send data on the Tx pin, and receive data on the Rx pin. Based on your previous posts, it sounds like you can send data to HyperTerminal (PIC --> PC), right? The problem is that you cannot receive data from HyperTerminal (PC --> PIC), also correct?
The next step, is to tell us what you have connected between the PIC UART pins and your PC. Are you using a MAX232 type device, or a USB-to-TTL converter perhaps?
What is the Vcc voltage of your PIC?
If you are using a USB-to-TTL converter, post a link to the datasheet! _________________ John
If it's worth doing, it's worth doing in real hardware! |
nailuy
nailuy
Posted: Tue Apr 12, 2016 3:14 pm |
I'm back with one discovery.
When I set by software pin for RX and pin for TX, pin the same like are UART hardware compiler recognize and is not working, when I change between them or any other pin is working so is not normally.... |
