SDHC driver for CCS **free**
hssn601
PostPosted: Tue Jun 10, 2014 4:50 am     Reply with quote
This code require mmcsd.c for read and write operations.
Tested SD cards
2,4,8,16 gb
you only have to call InitializeSD() instead of mmcsd_init()
InitializeSD =1 if success
InitializeSD =0 if unsuccessful
after that you can use ccs mmcsd.c with SDHC memory cards.
MySD.c
//Slightly modified SD initialization
MMCSD_err mmcsd_init()
   //fprintf(SERIAL2,"\r\n---SD-SPI initialization....\r\n");
   unsigned int8 i,r1,ra,rb;
   g_CRC_enabled = TRUE;
   g_mmcsdBufferAddress = 0;
   output_drive(MMCSD_PIN_SCL);
   output_drive(MMCSD_PIN_SDO);
   output_drive(MMCSD_PIN_SELECT);
   output_float(MMCSD_PIN_SDI);
   //delay_ms(1000);
   //spi_xfer(mmcsd_spi, 0x55);
   //delay_ms(1000);
   OUTPUT_HIGH(MMCSD_PIN_SELECT);
   spi_xfer(mmcsd_spi, 0xFF);
   OUTPUT_LOW(MMCSD_PIN_SELECT);
   mmcsd_deselect();
   delay_ms(20);
   /* begin initialization */
   //fprintf(SERIAL2,"\r\nIdle in\r\n");
   i = 0;
   do
      mmcsd_select();
      r1=mmcsd_go_idle_state();
      mmcsd_deselect();
      i++;
      if(i >= 250)
         mmcsd_deselect();
         return r1;
   } while(!bit_test(r1, 0));
   //fprintf(SERIAL2,"Idle out\r\n");
   // following initialization is for MMC card only
   i = 0;
   do
      delay_ms(20);
      mmcsd_select();
      //r1=mmcsd_send_op_cond();//for MMC card
      ra=mmcsd_app_cmd();
      mmcsd_deselect();
      //spi_xfer(mmcsd_spi, 0xFF);
      delay_us(100);
      mmcsd_select();
      rb=mmcsd_sd_send_op_cond();
      mmcsd_deselect();
      i++;
      if(i >=250)
         mmcsd_deselect();
         return r1;
   } while((ra | rb) & MMCSD_IDLE);
   /* figure out if we have an SD or MMC */
  // mmcsd_select();
  // r1=mmcsd_app_cmd();
  // r1=mmcsd_sd_send_op_cond();
  // mmcsd_deselect();
   /* an mmc will return an 0x04 here */
   /*if(r1 == 0x04)
      g_card_type = MMC;
      g_card_type = SD;
   // set block length to 512 bytes
   printf("Card Type: %X\r\n",r1);*/
   mmcsd_select();
   r1 = mmcsd_set_blocklen(MMCSD_MAX_BLOCK_SIZE);
   if(r1 != MMCSD_GOODEC)
      mmcsd_deselect();
      //fprintf(SERIAL2,"Block error EN: %X\r\n",r1);
      return r1;
   mmcsd_deselect();
   //fprintf(SERIAL2,"Return from block EN: %X\r\n",r1);
   /* turn CRCs off to speed up reading/writing */
   mmcsd_select();
   r1 = mmcsd_crc_on_off(0);//sharry: changed from 0 to 1
      mmcsd_deselect();
      //return r1;//for proteus simulation only
     //fprintf(SERIAL2,"CRC error on/off: %X\r\n",r1);
   mmcsd_deselect();
   //fprintf(SERIAL2,"Return from CRC OFF: %X\r\n",r1);
   //r1=0;
   r1 = mmcsd_load_buffer();
   //fprintf(SERIAL2,"\r\n---SD successfully initialized...\r\n");
   //delay_ms(2000);
   return r1;
//SDHC Initialization
#use spi(FORCE_HW, MASTER, DI = MMCSD_PIN_SDI, DO = MMCSD_PIN_SDO, CLK = MMCSD_PIN_SCL, BITS = 8, MSB_FIRST, MODE = 0, stream = mmcsd_spi, CLOCK_HIGH = 1, CLOCK_LOW = 1)
unsigned int8 sd_cmd1[9] = {
   0xFF, 0x40, 0x00, 0x00, 0x00, 0x00, 0x95, 0xFF, 0xFF
unsigned int8 sd_cmd2[13] = {
   0xFF, 0x48, 0x00, 0x00, 0x01, 0xAA, 0x87, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF
unsigned int8 sd_cmd3[8] = {
   0xFF, 0x77, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xFF
unsigned int8 sd_cmd4[9] = {
   0xFF, 0x69, 0x40, 0x00, 0x00, 0x00, 0xFF, 0xFF, 0xFF
unsigned int8 sd_cmd5[10] = {
   0xFF, 0x7A, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0xFF
unsigned int8 send_spi(unsigned int8 spi_msg) {
   static unsigned int8 spi_rcv;
   spi_rcv = spi_xfer(mmcsd_spi, spi_msg);
   return spi_rcv;
unsigned int8 Send_Command(unsigned int8 cmd[], unsigned int8 size) {
   static unsigned int8 p;
   static unsigned int8 resp;
   delay_us(20);
   //mmcsd_select();
   for (p = 0; p < size; p++) {
      resp = send_spi(cmd[p]);
   //mmcsd_deselect();
   return resp;
void Initialize(void) {
   mmcsd_deselect();
   delay_us(50);
int1 Initialize_SDHC(void) {
   int1 done = 0;
   static unsigned int8 rcv;
   static unsigned int16 count = 0;
   //Send Dummys
   Initialize();
   mmcsd_select();
   Send_Command(sd_cmd1, 9);
   mmcsd_deselect();
   mmcsd_select();
   Send_Command(sd_cmd2, 13);
   mmcsd_deselect();
   while (!done) {
      mmcsd_select();
      rcv = Send_Command(sd_cmd3, 8);
      if (rcv == 0x00) {
         done = 1;
      } else {
         mmcsd_deselect();
      mmcsd_select();
      rcv = Send_Command(sd_cmd4, 9);
      if (rcv == 0x00) {
         done = 1;
      } else {
         mmcsd_deselect();
      count++;
      if (count == 5000) {
         return 0;
   mmcsd_select();
   if (Send_Command(sd_cmd5, 10) == 0xC0) {
      send_spi(0xFF);
      send_spi(0xFF);
      send_spi(0xFF);
      send_spi(0xFF);
      return 1;
   } else {
      return 0;
      mmcsd_deselect();
Function: InitializeSD()
Return 1 if sucess
Return 0 if unsucessful
int1 InitializeSD(void) {
   if (Initialize_SDHC()) {
      return 1;
   } else if (!mmcsd_init()) {
      return 1;
   } else {
      return 0;
no more searching for 2gb SD cards Very Happy
Best Regards,
Hassan Shakeel
soonc
So many code errors But has great potential
PostPosted: Tue Aug 22, 2017 10:27 pm     Reply with quote
There are so many code error in this example that you posted.
Just one example:
last line:
  } else {
      return 0;
      mmcsd_deselect(); // This never gets called !
Not so much an error but why do you repeat code with different syntax!
is already in the example as : mmcsd_deselect();
and
is also in the example mmcsd_select();
Also you would have to NOT declare #case to avoid errors
OUTPUT_HIGH() more commonly output_high() with #case declared.
Updated: 2017/Sept/4
I revisited this post: and everything I said I still firmly believe to be true.
However this code comes close to actually working with some memory cards that are difficult.
Thanks.
