timer1 problem
baris_akinci
timer1 problem
PostPosted: Thu Mar 24, 2016 2:38 am     Reply with quote
Hello, I have been trying to generate SPWM by using Timer1 for two output pins of 16f628a. Actually, I find and optimize this code and test it on real board. It worked well for me.
 #include <16f628a.h>
#FUSES NOWDT, INTRC_IO, NOPROTECT, NOBROWNOUT, NOMCLR, NOCPD
unsigned int8 pwm_valA=0,pwm_valB=0,pwm_dutyA=0,pwm_dutyB=0;
#int_timer1
void timer1_kesmesi()
      set_timer1(65500);
      if(++pwm_valA<pwm_dutyA) output_high(pin_a0);
      else output_low(pin_a0);
      if(++pwm_valB<pwm_dutyB) output_high(pin_a1);
      else output_low(pin_a1);
   set_tris_a(0X00);
   set_timer1(15035);
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
   enable_interrupts(int_timer1);
       pwm_dutyA=50;
       pwm_dutyB=50;
But if I move this code block into another project as a part of another simulation, the speed of outputs (gradually ON/OFF situation) goes faster, and I can not control it!! Internal OSC and OSC speed are same, prescaler is same, outputs are same!
Please let me know why this happens and how can I control it. Thanks in advance.
PostPosted: Thu Mar 24, 2016 5:33 am     Reply with quote
re:
Simulation is NOT the same as Real World testing !
First NO 'simulator' actually works 100% properly....
2nd You don't show the 'new' code, only what did work, so we can't 'guess' what is different about version #2.
You need to post your 2nd program for any help.
baris_akinci
timer1 problem
PostPosted: Thu Mar 24, 2016 5:42 am     Reply with quote
You are right Jay, sorry. here is the second code..
 #include <16F628A.h>
#FUSES  NOWDT,NOPROTECT, NOBROWNOUT, NOLVP,NOCPD
#FUSES INTRC_IO
#use fast_io(a)
#use delay(internal=4000000)
#use rs232(baud=2400,xmit=PIN_B2,rcv=PIN_B1,ERRORS)
#priority  rda,timer1
#define LED1 pin_a0
#define LED2 pin_a1
#define LED3 pin_a2
#define LED4 pin_a3
char c[20];
char kapat[10];
int counter=1;
int durum=0;
int index = 0;
unsigned int inc=0;
#int_rda
void RDA_isr(void)
          // rda sub-program, its about the sychronization
 #int_timer1
      set_timer1(65500);
      output_low(LED1); output_low(LED3);
      if(++pwm_valA<pwm_dutyA)output_high(LED2);
      else output_low(LED2);
      if(++pwm_valB<pwm_dutyB)output_high(LED4);
      else output_low(LED4);
void sim1() {
               int i=0;
                           output_high(LED1);output_high(LED2); for(i=0;i<70;i++) {delay_ms(1); }
                           output_low(LED1);output_low(LED2);   for(i=0;i<70;i++) {delay_ms(1); }
                           output_low(LED1);output_low(LED2);   for(i=0;i<200;i++) {delay_ms(1); }
                           output_high(LED3);output_high(LED4); for(i=0;i<70;i++) {delay_ms(1); }
                           output_low(LED3);output_low(LED4);   for(i=0;i<70;i++) {delay_ms(1); }
                           output_low(LED3);output_low(LED4);   for(i=0;i<70;i++) {delay_ms(1);}
                           output_low(LED3);output_low(LED4);   for(i=0;i<200;i++) {delay_ms(1); }
void sim2() {
                int b=0;
                           output_high(LED1); for(b=0;b<50;b++){delay_ms(1);    }
                           output_low(LED1); for(b=0;b<50;b++){delay_ms(1);     }
                           output_high(LED2); for(b=0;b<50;b++){delay_ms(1);    }
                           output_low(LED2);for(b=0;b<50;b++){delay_ms(1);      }
                           output_high(LED3); for(b=0;b<50;b++){delay_ms(1);    }
                           output_low(LED3);for(b=0;b<50;b++){delay_ms(1);      }
                           output_high(LED4); for(b=0;b<50;b++){delay_ms(1);    }
                           output_low(LED4);for(b=0;b<50;b++){delay_ms(1);      }
                        for(b=0;b<150;b++){delay_ms(1);  }
                           output_low(LED1);for(b=0;b<50;b++){delay_ms(1);      }
void sim3() {
                  int h=0;
                            for(h=0;h<250;h++){delay_ms(1);    }
                            output_toggle(LED1);output_toggle(LED2);output_toggle(LED3);output_toggle(LED4);
void sim4() {
                  int a=0;
                           output_high(LED1); output_high(LED2);output_low(LED3);output_low(LED4);
                           for(a=0;a<250;a++){delay_ms(1);    }
                           output_low(LED1); output_low(LED2);output_high(LED3);output_high(LED4);
void sim5() {
                  int d=0;
                           output_high(LED1); output_high(LED3);output_low(LED2);output_low(LED4);
                           for(d=0;d<250;d++){delay_ms(1);    }
                           output_low(LED1); output_low(LED3);output_high(LED2);output_high(LED4);
   set_timer1(15035);
 setup_timer_1(T1_INTERNAL| T1_DIV_BY_1);
 enable_interrupts(int_rda);
 set_tris_a(0x00);
                      if(inc==1) {
                                      while(inc==1) {sim1();}
                      if(inc==2) {
                                      while (inc==2){sim2();}
                      if(inc==3) {
                                      while (inc==3){sim3();}
                      if(inc==4) {
                                      while (inc==4){sim4();}
                      if(inc==5) {
                                      while(inc==5) {
                                                     pwm_dutyA=50;
                                                     pwm_dutyB=50;
                                                     enable_interrupts(GLOBAL); }
                      if(inc==6) inc=1;
                      if(inc==15) { disable_interrupts(INT_TIMER1); output_low(LED1);output_low(LED2);output_low(LED3);output_low(LED4);}
I want to make some LED simulation for fun. all sim() is different to each other and just one simulation remain that is gradually ON/OFF the LEDs!!
PostPosted: Thu Mar 24, 2016 8:43 am     Reply with quote
comment
1) I can't see where the variable 'inc' ever gets changed. You preset it to zero. In main() all of your if( tests)... always fail as inc=0 .
