New compiler errors
SeeCwriter
New compiler errors
PostPosted: Thu Feb 04, 2016 1:02 pm     Reply with quote
I installed the new compiler version, v5.055, and now I'm getting the following
errors on an existing project that I didn't get with prior versions.
void func1( char *p )
  char *ptr, dlim[2];
  dlim[0] = ';';
  dlim[1] = '\0';
  ptr = strtok( p, dlim );
  while( ptr != NULL ) {
     process_cmd( ptr );
     ptr = strtok( NULL, dlim );  // <-- Pointer types do not match.
void func2( char *p )
   int16_t val;
   float fval;
   // set 'val' to some value.
   fval = atof( p+val );       // <-- Pointer types do not match.
This is for an 18F67K22.
SeeCwriter
PostPosted: Thu Feb 04, 2016 3:33 pm     Reply with quote
To remove the strtok() warning requires NULL to be cast as a char*.
But no amount of casting removes the atof() warning. I had to replace
atof() with strtof() and cast both arguments as char*.
Yet, I use atoi() with the same pointer argument as atof(), and get no
pointer warnings. ??
PostPosted: Thu Feb 04, 2016 10:01 pm     Reply with quote
This line in stdlib.h is causing the pointer mismatch warning:
#define atof(s)   strtof(s, 0)
One way to fix it is to add the two lines shown in bold below to your main
source file:
#include <18F67K22.h>
#fuses INTRC_IO, NOWDT
#use delay(clock=4M)
#include <string.h>
#include <stdint.h>
#include <stdlib.h>
#undef atof
#define atof(s) strtof(s, (char *)0)
