JerryR
Cant put PIC16F1784 to sleep |
Posted: Wed Nov 04, 2015 9:51 am |
Hello Group:
I've been beating my head against a problem where I cant get a PIC16F1784 to stay in sleep mode. I've been very successful in the past with other Microchip controller to sleep, but for some reason not this project.
I've paired down the code to its basic functionality shown below. Here I increment a counter in Timer0 interrupt until reaching 5000 (3 seconds or so) and attempt sleep. Microcontroller never enters sleep as evident by current draw of 5 mA. I expect less than 100uA.
CAN ANYONE SPOT SOMETHING i'M NOT SEEING?
Thanks for the groups help.
//==================sleeptest.c
#include <16F1784.h>
#include <sleeptest.h>
#INCLUDE <math.h>
//Prototypes
void Go_To_Sleep (void);
#INT_TIMER0
void clock_isr(void)
int8 Num_Beeps;
set_timer0(60); //preload TMR0
if (Sleep_Tmr++ >= 5000)
Go_To_Sleep();
restart_wdt();
clear_interrupt(INT_EXT);
setup_wdt(WDT_ON|WDT_32S); //set watchdog timer to reset in ~3 secs.
disable_interrupts(GLOBAL); // disable all interruptsleep(); //sleep for one seccond
set_timer0(60);
sleep();
delay_cycles(1);
setup_wdt(WDT_OFF);
Sleep_Tmr= 0;
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_4);
set_timer0(60); //preset timer0
enable_interrupts(INT_TIMER0); // Enable timer0 interrupt
enable_interrupts(GLOBAL); // Enable all interrupts
while (True)
//==================sleeptest.h
#device adc=8
#FUSES NOPUT //Power up timer off for debugging
#use delay(int=8000000)
//#use spi(MASTER, DI=Data_In, CLK=SClk, BAUD=100000, BITS=18, MODE=1, stream=AD)
//VARIABLES
int32 Sleep_Tmr;
Posted: Wed Nov 04, 2015 11:56 am |
Try doing a more simple test. Disconnect all other circuits from the PIC
except for the MCLR pullup resistor and the following LED circuit:
PIC 470 ohms LED
pin -----/\/\/\/------->|----
B0 |
----- Ground
Also, disconnect your programmer from the board (Pickit 3, ICD3, etc).
If it's connected during current measurement, it will draw a few ma and
ruin your low sleep current test.
#fuses INTRC_IO, NOWDT
#use delay(clock=8M)
#define LED_PIN PIN_B0
// Set all unused i/o pins as low-level outputs
// to avoid spurious current from floating inputs.
output_a(0);
output_b(0);
output_c(0);
output_d(0);
output_e(0);
// Turn LED on for 1 second to show PIC is running.
output_high(LED_PIN);
output_low(LED_PIN);
sleep(); // Then sleep. LED should stay off.
// If the PIC is not sleeping, then the LED will blink rapidly.
output_toggle(LED_PIN);
delay_ms(250);
JerryR
Posted: Wed Nov 04, 2015 12:06 pm |
Will do stand-by
Jerry |
JerryR
Posted: Wed Nov 04, 2015 2:09 pm |
PCM:
Thanks for the exercise. It always pays to reduce to minimum code and hardware when troubleshooting a problem. I had NOWDT and Timer0 interrupts were interrupting my sleep.
Sleep current down to 17uA. Would like lower, but that should satisfy my requirements.
Thanks again |
Posted: Wed Nov 04, 2015 2:11 pm |
//VARIABLES
// add some INIT
int32 Sleep_Tmr=0;
seems like a useful play |
JerryR
Posted: Wed Nov 04, 2015 2:50 pm |
asmboy: Yes, good catch. Before dumbing down the code, I had Sleep_Tmr initialized in main.
All the best! |
Posted: Wed Nov 04, 2015 3:03 pm |
Quote: | Sleep current down to 17uA. Would like lower, but that should
satisfy my requirements. |
Are you using the "F" device (and not the "LF") ?
If so, you have the option of putting the LDO regulator into low power
mode during sleep.
Read section 9.2 in the 16F1784 data sheet for more details on this.
The low power mode is disabled if certain peripherals are active in
sleep mode, such as BOR, WDT, and interrupts. This is given in section 9.2.2.
Also, the implication is that VREGPM is automatically reset back to 0
when the PIC leaves sleep mode.
Also, the wake-up time from sleep is increased by several usec when
the LDO low-power-in-sleep mode is used. Graphs are given for this
in the data sheet's electrical section. Data sheet:
http://ww1.microchip.com/downloads/en/DeviceDoc/40001637C.pdf
#bit VREGPM = getenv("BIT:VREGPM")
VREGPM = 1; // Enable low power mode for the LDO during sleep
sleep();
JerryR
Posted: Wed Nov 04, 2015 6:14 pm |
Yes! I am using the "F" not LF and I will give that a try as well. Thanks for your suggestion, I've tried that before with a PIC16F688.
All the best my friend. |
