AT-commands with 16F877
viewgsm
PostPosted: Sat Nov 10, 2001 8:45 pm     Reply with quote
I try to send AT commands by PIC16F877 to my GSM C35 phone
I use PIC BASIC PRO compiler
useing Hserout command on 19200 baud !
but not working here is the code
Note : I use 8 Mhz Xtal to get 19200 baud
DEFINE HSER_RCSTA 90h
DEFINE HSER_TXSTA 24h
DEFINE HSER_BAUD 9600
DEFINE HSER_SPBRG 25
p:
Pause 1000
HSerout ["ATDT0101803180;"]
Pause 1000
GoTo p
any HELP !?
Original Post ID: 1049
Tomi
Re: AT-commands with 16F877
PostPosted: Sun Nov 11, 2001 10:28 am     Reply with quote
This is a dedicated CCS C forum and not for PIC BASIC PRO.
However, because the C35 default baud rate is 19200 you must either modify your line:
"DEFINE HSER_BAUD 9600" to "DEFINE HSER_BAUD 19200"
or enter the "AT+IPR=9600" command into your C35 using a terminal emulator program.
:=I try to send AT commands by PIC16F877 to my GSM C35 phone
:=I use PIC BASIC PRO compiler
:=useing Hserout command on 19200 baud !
:=but not working here is the code
:=Note : I use 8 Mhz Xtal to get 19200 baud
:=DEFINE HSER_RCSTA 90h
:=DEFINE HSER_TXSTA 24h
:=DEFINE HSER_BAUD 9600
:=DEFINE HSER_SPBRG 25
:=p:
:=Pause 1000
:=HSerout ["ATDT0101803180;"]
:=Pause 1000
:=GoTo p
:=any HELP !?
Original Post ID: 1055
viewgsm
for Tomi Re: AT-commands with 16F877
PostPosted: Sun Nov 11, 2001 12:17 pm     Reply with quote
Thanks v. much dear ,
I'm sorry I'm not good at C , but I need to make program
for dail and hang up with 16f877 ,, If you don't mind to
help me make it by C , I pay you ,,, like work deal ,, Please
Thanks v. much
:=This is a dedicated CCS C forum and not for PIC BASIC PRO.
:=However, because the C35 default baud rate is 19200 you must either modify your line:
:="DEFINE HSER_BAUD 9600" to "DEFINE HSER_BAUD 19200"
:=or enter the "AT+IPR=9600" command into your C35 using a terminal emulator program.
:=:=I try to send AT commands by PIC16F877 to my GSM C35 phone
:=:=I use PIC BASIC PRO compiler
:=:=useing Hserout command on 19200 baud !
:=:=but not working here is the code
:=:=Note : I use 8 Mhz Xtal to get 19200 baud
:=:=DEFINE HSER_RCSTA 90h
:=:=DEFINE HSER_TXSTA 24h
:=:=DEFINE HSER_BAUD 9600
:=:=DEFINE HSER_SPBRG 25
:=:=p:
:=:=Pause 1000
:=:=HSerout ["ATDT0101803180;"]
:=:=Pause 1000
:=:=GoTo p
:=:=any HELP !?
Original Post ID: 1057
