Robot / Pic Project Sound Generator Chip - RS232
Arizona Chris
PostPosted: Sun Sep 13, 2015 12:47 pm     Reply with quote
This allows you to take the load off your main processor and generate 13 different interesting chirps, peeps, whoops and sirens with your PIC project. I developed these over the years building various robots. The sound chip is a standard PIC16F628a processor and can be addressed with a single byte from any master processor using RS232 protocol and 9600kb speed.
I also have a complete web write up, with schematics and a sound clip:
http://www.schursastrophotography.com/PICprojects/soundchip.html
Here is an example of what the master processor would send over a single wire to the PIC sound chip for a sound:
#use rs232(baud=9600, xmit=Pin_B2, bits=8, parity=N,STREAM=SOUND)
   s=2  //can be 1 - 13
   fputc(s,SOUND);
Next, here is the actual code for the sound chip - a standard 16F628a. You can see how much ROM space we are saving on our main processor!
//Chris Schur
//(soundchp 16F628)
//Date:  9/7/15
/*Description of this Program:
This program sends out 13 different robot sounds via serial selection from another processor.
//I/O Designations ---------------------------------------------------
// RA0:
// RA1:
// RA2:
// RA3:
// RA4:  (Open Collector output)
// RA5:  (MCLR)
// RA6:  Xtal  Output
// RA7:  Xtal  Input
// RB0:  SERIAL INPUT
// RB1:
// RB2:
// RB3:  SOUND OUT
// RB4:
// RB5:
// RB6:
// RB7:
//Include Files:
#include <16F628.h>  //Normally chip, math, etc.  used is here.
//Directives and Defines:
#fuses NOPROTECT,HS,NOWDT   //xtal is used
#use delay(crystal=10MHz)   //xtal speed
#use fast_io(ALL)          //must define tris below in main when using this
#use rs232(baud=9600, rcv=Pin_B0, bits=8, parity=N)
#define SPKR Pin_B3
//Global Variables:
int16 n; //counting var
int16 d;  //sound delay var
int8 x;  //counting var
int8 sound = 0;  //selection for sound produced
//Functions/Subroutines, Prototypes:
void beep1(void);
void beep2(void);
void beep3(void);
void euro1(void);
void euro2(void);
void rampdn(void);
void rampup(void);
void tripplewhoop(void);
void siren(void);
void cricket(void);
void tripplecricket(void);
void twodutybeeps(void);
void twodutybeeps2(void);
//-- Main Program
void main(void) {
   // Set TRIS I/O directions, define analog inputs, comparators:
      set_tris_A(0b01111110);
      set_tris_B(0b11110001);
      //(analog inputs digital by default)
   //Initialize variables and Outputs:  --------------------------------------
   output_low(SPKR);
   //Setup for timers, PWM, and other peripherals:
//MAIN LOOP:
while (true)   {
sound = getc();//select sound
  switch (sound) {
  case 0:
      output_low(SPKR);
  case 1:
      beep1();
      sound = 0;
  case 2:
      beep2();
      sound = 0;
  case 3:
      beep3();
      sound = 0;
  case 4:
      euro1();
      sound = 0;
  case 5:
      euro2();
      sound = 0;
  case 6:
      rampdn();
      sound = 0;
  case 7:
      rampup();
      sound = 0;
  case 8:
      tripplewhoop();
      sound = 0;
  case 9:
     siren();
     sound = 0;
  case 10:
      cricket();
      sound = 0;
  case 11:
      tripplecricket();
      sound = 0;
  case 12:
      twodutybeeps();
      sound = 0;
  case 13:
      twodutybeeps2();
      sound = 0;
    }  //switch
  }  //while
}  //main
//********* Functions which have prototypes at top of program ****************
//Beep 1:                     //Short single beep
void beep1(void)  {
   for(n=1; n<=50; n=n+1)  {
   output_high(SPKR);
   delay_ms(1);
   output_low(SPKR);
   delay_ms(1);
   return; }
//Beep2:                      //double beep
void beep2(void) {
beep1();
delay_ms(50);
beep1();
return;  }
//Beep3:                       //Low tone beep
void beep3(void)  {
   for(n=1; n<=25; n=n+1)  {
   output_high(SPKR);
   delay_ms(2);
   output_low(SPKR);
   delay_ms(2); }
   return;  }
//Euro Beep1:                 //fast Two tone three times
void euro1(void)  {
   beep1();
   beep3();
   beep1();
   beep3();
   beep1();
   beep3();
   return;   }
//Euro Beep2:                  //standard slow beep
void euro2(void)  {
   for(n=1; n<=400; n=n+1)  {
   output_high(SPKR);
   delay_us(650);
   output_low(SPKR);
   delay_us(650);
   for(n=1; n<=200; n=n+1)  {
   output_high(SPKR);
   delay_us(1200);
   output_low(SPKR);
   delay_us(1200); }
   output_high(SPKR);
   delay_us(650);
   output_low(SPKR);
   delay_us(650);
   output_high(SPKR);
   delay_us(1200);
   output_low(SPKR);
   delay_us(1200); }
   output_high(SPKR);
   delay_us(650);
   output_low(SPKR);
   delay_us(650);
   output_high(SPKR);
   delay_us(1200);
   output_low(SPKR);
   delay_us(1200); }
   return;   }
//Ramping tones -----------------------------
void rampdn(void)  {    //high tone to low ramp
d=1500;
for(n=1; n<=500; n=n+1)  {
   output_high(SPKR);
   delay_us(d);
   output_low(SPKR);
   delay_us(d);
   d++;   }
   return;   }
void rampup(void)  {     //low tone to high ramp
d=1500;
   output_high(SPKR);
   delay_us(d);
   output_low(SPKR);
   delay_us(d);
   d--;   }
   return;   }
void tripplewhoop(void)  {  //go  1200 to 600 us
  for(x=1; x<=3; x++)  {
   d=1200;
   output_high(SPKR);
   delay_us(d);
   output_low(SPKR);
   delay_us(d);
   d = d-3;
   return;   }
void siren(void)  {  //sort of a sick sounding up down wail
   rampup();
   rampdn();
//  CREATURE SOUNDS:
void cricket(void)   {  //single chirp
for (x=0; x<=10; x++)  {
      output_high(SPKR);
      delay_us(250);
      output_low(SPKR);
      delay_us(250);    }
      delay_ms(20);
      output_high(SPKR);
      delay_us(312);
      output_low(SPKR);
      delay_us(312);    }
      delay_ms(20);
      output_high(SPKR);
      delay_us(312);
      output_low(SPKR);
      delay_us(312);    }
      delay_ms(20);
      output_high(SPKR);
      delay_us(312);
      output_low(SPKR);
      delay_us(312);    }
      delay_ms(20);
      output_high(SPKR);
      delay_us(312);
      output_low(SPKR);
      delay_us(312);    }
      delay_ms(20);
void tripplecricket(void)  {
cricket();
delay_ms(600);
cricket();
delay_ms(600);
cricket();  }
void twodutybeeps(void)  {   //1 khz beeps
//first beep 50% duty:
for(n=1; n<=100; n=n+1)  {
   output_high(SPKR);
   delay_us(500);
   output_low(SPKR);
   delay_us(500);  }
//second beep 10% duty:
   output_high(SPKR);
   delay_us(25);
   output_low(SPKR);
   delay_us(975);  }
void twodutybeeps2(void)  {   //1 khz beeps
   output_high(SPKR);
   delay_us(250);
   output_low(SPKR);
   delay_us(250);  }
   output_high(SPKR);
   delay_us(25);
   output_low(SPKR);
   delay_us(475);  }
