Unable to display function in 16 x 2 LCD in second Line
anilmanisingh
PostPosted: Thu Sep 10, 2015 12:20 am     Reply with quote
Hi , Everyone
I am using two push buttons to display two parameters at same time.
But I am unable to do so. I want to change my program each time I press the pushbutton1 in Line 1 and in Line 2 I want to change function F with each press of the other pushbutton2.
Please help me.
#include <16f876a.h>
#fuses XT,NOWDT,NOPROTECT,PUT,NOLVP
#use delay (clock=4000000)
#use standard_io(b)
#define use_portb_lcd TRUE
#include<lcd.c>
/// Program Function
void program(char);
void freq(char);
///PROGRAM
   char option=0;
   char option2=0;
   setup_ccp1(CCP_PWM);
   lcd_init();
   program(option);
   freq(option2);
   for(;;){
      if(!input(PIN_A0)){
         do{
         }while(!input(PIN_A0));
         option++;
         if(option>9)
            option=0;
         program(option);
       if(!input(PIN_A1)){
         do{
         }while(!input(PIN_A1));
         option2++;
         if(option2>4)
            option2=0;
         freq(option2);
void program(char menu)
   lcd_putc("\f");
   switch(menu){
      case 0:
            lcd_gotoxy(1,1);
            printf(lcd_putc,"\fPROGRAM:   M.STI");
      case 1:
            lcd_gotoxy(1,1);
            printf(lcd_putc,"\fPROGRAM:   I.LOS");
      case 2:
            lcd_gotoxy(1,1);
            printf(lcd_putc,"\fPROGRAM:   W.LOS");
      case 3:
            lcd_gotoxy(1,1);
            printf(lcd_putc,"\fPROGRAM:   B.TON");
      case 4:
            lcd_gotoxy(1,1);
            printf(lcd_putc,"\fPROGRAM:   B.SCU");
      case 5:
            lcd_gotoxy(1,1);
            printf(lcd_putc,"\fPROGRAM:   B.SHA");
      case 6:
            lcd_gotoxy(1,1);
            printf(lcd_putc,"\fPROGRAM:   B.COR");
      case 7:
            lcd_gotoxy(1,1);
            printf(lcd_putc,"\fPROGRAM:   B.FIR");
      case 8:
            lcd_gotoxy(1,1);
            printf(lcd_putc,"\fPROGRAM:   TUMMY");
       case 9:
            lcd_gotoxy(1,1);
            printf(lcd_putc,"\PROGRAM:   F.LIF");
void freq(char menu)
   lcd_putc("\f");
   switch(menu){
      case 0:
            lcd_gotoxy(1,2);
            printf(lcd_putc,"\nF : 1 ");
      case 1:
            lcd_gotoxy(1,2);
            printf(lcd_putc,"\nF : 2 ");
      case 2:
            lcd_gotoxy(1,2);
            printf(lcd_putc,"\nF : 3 ");
      case 3:
            lcd_gotoxy(1,2);
            printf(lcd_putc,"\nF : 4 ");
      case 4:
            lcd_gotoxy(1,2);
            printf(lcd_putc,"\nF : 5 ");
PostPosted: Thu Sep 10, 2015 4:59 am     Reply with quote
Looks like the classic 'No debounce on the switches' problem.
Do a search for 'debounce' here and the code library for 20-30 solutions.
Also describe actual hardware( switch type, pullup, filter cap,etc.)
Jay
Sam_40
PostPosted: Thu Sep 10, 2015 6:51 am     Reply with quote
IMHO, I think its the "\f".
PostPosted: Thu Sep 10, 2015 10:00 am     Reply with quote
lcd_putc("\f");
switch(menu){
case 0:
lcd_gotoxy(1,2);
You go to the start of line 2 with the lcd_gotoxy(). Then you send a
newline in the printf. Where will the \n take you to ? You won't be on line 2.
