		| Author | Message |
		| sergioigel
				| puts printf rs232 with PICF16F917 |
				|  Posted: Mon Apr 10, 2017 7:28 am |   |
				| hi, I try to use rs232 with the PIC16F917 but the program freezes when i use the routine PUTS or PRINTF.
 Somebody help me ?
 I try variations but nothing works.
  	  | Code: |  	  | #use delay(clock=20000000)//,RESTART_WDT)
 #use rs232(baud=115200, xmit=pin_c6, rcv=pin_c7)
 //#use rs232(baud=115200, BRGH1OK, xmit=pin_c6, rcv=pin_c7, PARITY=N, BITS=8)
 //#use rs232(baud=115200, BRGH1OK, xmit=pin_c6, rcv=pin_c7, PARITY=N, BITS=8, TXISR)
 //#use rs232(BAUD=115200, BRGH1OK, MAX_ERROR=9, UART1, XMIT=PIN_c6, RCV=PIN_c7, PARITY=N, BITS=8, STOP=1, TXISR, STREAM=uart1, ERRORS)
		| PCM programmer
				|  Posted: Mon Apr 10, 2017 8:19 am |   |
				| Post a complete test program with the #include for the PIC, any #device statements, #fuses, #use delay(), #use rs232(), main(), and some short
 code that shows the problem.  Example of a test program:
 http://www.ccsinfo.com/forum/viewtopic.php?t=55769&start=9
 Also post your compiler version.  It's given at the top of the .LST file
 after a successful compilation.   It's a number such as 5.071 or 4.141, etc.
 Also, tell us how you are doing the testing ?  What external circuits do
 you have connected to pins C6 and C7 ?   What program or method are
 you using to see the characters sent by printf() ?
		| sergioigel
				|  Posted: Mon Apr 10, 2017 9:50 am |   |
				| I use multiple files to divide the source. When i put the files together to post here, i try to compile and then it works now. I will see what is the problem in other locations in my project. |  |
 | You cannot post new topics in this forum You cannot reply to topics in this forum
