asmboy
| things i do not know , of which there are many - here are 2 |
Posted: Wed Jun 03, 2015 2:10 pm |
I'm trying to improve a storage efficent data structure using
an INT1 sparse array to record fault states in 1536 different
addressable locations.
presently the results of a scan are stored in this:
INT1 missing[96][16]
which fits in 192 BYTES of an 18F4620 PIC
at start of a 'run' all elements set to 0. With nested loops. ;-((
Then , When external devices are scanned a single array element at
missing[address][excite]=1;
is set true if one of 96 addresses when cross tested by
one of 16 line-exciters is not responding.
After a complete 1536 scan, only a very few or sometimes NONE of the bits will be set in 'missing[][]'
Without using nested loops i'd like to be able to also view the 1536
locations as 192 bytes , testing each byte for non-zero and THEN decoding
what actual bit is "it" with a bit of bit-shifting.
I'd also like to be able to RAPIDLY rezero the 192 bytes without loops too.
Ideally i would aim a pointer somewhere and stuff++ 192 ASCIIZ's
down it's throat ;-))
I have not figured out the appropriate structure to do it with.
Ideas welcome.
And then there is this:
I ONLY use the command line.
I have long wanted to add a default alternative
at compile time for code libraries of my own
outside the current project folder and outside the CCS mothership
version folder as well
i have struck out completely with making
I=" path data ......"
work by creating a like named .PJT or .CCSPJT file with the
prefix of my source that contains
I="C:\....path ......;" line in it.
Is there a known "works in the source file itself " compiler directive
that basically does an
I+=" more path info;"
type of function in my source file header right at line #1 ??
so i can ADD to the CCS intrinsics ??
and not replace it ?
Is there such a directive i can add to my source file ?
I just can't locate it , if it is real . |
Posted: Wed Jun 03, 2015 2:26 pm |
Union.....
Or use #byte.
So:
union {
int1 missing[96][16];
int8 b[192];
} data;
data.missing[x][y] accesses the bits just as missing does, but data.b[n] accesses the bytes.
This is generic C, as opposed to any 'special' CCS feature. The next is an alternative CCS way of doing this:
int8 b[192];
#byte b=missing //this locates 'b' into the same memory space as missing
One of the features of #byte, is that if called with an already declared variable, it locates this at the given address. In this case the address of 'missing'.
On zeroing, memset:
Using the byte declarations, will set all 192 bytes to zero.
Use the PATH.
Have a .CMD file to set his so the default search location at the start is where you want.
Do your compile.
Reset PATH |
jeremiah
Posted: Wed Jun 03, 2015 2:41 pm |
EDIT: Just saw I was beaten to the punch but anyways I was gonna say:
#case
#include <24EP512GU810.h>
typedef struct{
int8 b0 : 1;
int8 b1 : 1;
int8 b2 : 1;
int8 b3 : 1;
int8 b4 : 1;
int8 b5 : 1;
int8 b6 : 1;
int8 b7 : 1;
} bits_t;
typedef union{
unsigned int8 bytes[192];
bits_t bits[192];
} view_t;
view_t view;
view.missing[0][0] = 1;
view.bytes[1] = 0x23;
view.bits[2].b1 = 1;
memset(&view,0,sizeof(view_t));
LST file results:
.................... view.missing[0][0] = 1;
00288: BSET.B 1000.0
.................... view.bytes[1] = 0x23;
0028A: MOV.B #23,W0L
0028C: MOV.B W0L,1001
.................... view.bits[2].b1 = 1;
0028E: BSET.B 1002.1
.................... memset(&view,0,sizeof(view_t));
00290: MOV #1000,W1
00292: MOV #0,W2
00294: REPEAT #BF
00296: CLR.B [W1++]
Nothing new new though as Ttelmah already covered that.
That's with 5.044
EDIT: sorry still had my pic24 in there, here is the output for yours
00030: BSF 04.0
00032: MOVLW 23
00034: MOVWF 05
00036: BSF 06.1
00038: CLRF FEA
0003A: MOVLW 04
0003C: MOVWF FE9
0003E: CLRF 00
00040: CLRF 02
00042: MOVLW C0
00044: MOVWF 01
00046: BRA 0004
asmboy
Posted: Wed Jun 03, 2015 3:10 pm |
Thanks for the assist to you both.
I don't mind admitting ignorance, but i try hard not to be wrong.
Your generosity with good advice is much appreciated
-d- |
