		| Author | Message |
		| No_Fear Guest
				| ADC Problem still continues |
				|  Posted: Wed Jun 04, 2003 4:34 am |   |
				| <font face="Courier New" size=-1>Hi,
 I'm still in trouble with adc function of 16F877A.I am using port A0,A1,A5,E0,E1,E2.When i measure voltage between ports and GND they are usually at 1 milivolt or 2 milivolts.But when i log them adc function returns 100-120 values equals to 2.0V - 2.5V.When i measure E2 it gives 50 milivolt when i dont apply voltage on it(when idle i mean)!! My device does not work properly now please help!!
 No_Fear
 My code :
 #include <16F877A.h>
 #device adc=8
 #use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7)
 int v1,v2,v3,v4,v5,v6;
 char ON;
 setup_adc_ports(ALL_ANALOG);
 setup_psp(PSP_DISABLED);
 setup_spi(FALSE);
 setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
 setup_timer_1(T1_DISABLED);
 setup_vref(FALSE);
 set_tris_d(0x00);
 ON = 1;
 printf("3A75D5FA\r\n");
 while (1)
 set_adc_channel( 0 );delay_us(100);v1 = read_adc();delay_us(100);
 set_adc_channel( 1 );delay_us(100);v2 = read_adc();delay_us(100);
 set_adc_channel( 4 );delay_us(100);v3 = read_adc();delay_us(100);
 set_adc_channel( 5 );delay_us(100);v4 = read_adc();delay_us(100);
 set_adc_channel( 6 );delay_us(100);v5 = read_adc();delay_us(100);
 set_adc_channel( 7 );delay_us(100);v6 = read_adc();delay_us(100);
 printf("Value:\%2X/\%2X/\%2X/\%2X/\%2X/\%2X!",v1,v2,v3,v4,v5,v6);
 if (ON == 1) {output_high(PIN_D2);ON = 0;} else {output_low(PIN_D2);ON = 1;}
 v1=0;v2=0;v3=0;v4=0;v5=0;v6=0;
 I upload schematic at www.mcu.cz/atm
 Please Helpp!!</font>
 ___________________________
 Original Post ID: 144515026
		| Tomi Guest
				| Re: ADC Problem still continues |
				|  Posted: Wed Jun 04, 2003 8:31 am |   |
				| Do you have any analog voltage on any input pin? Don't forget that the PIC has only one A/D converter. The analog inputs are multiplexed. After the multiplexer there is a S/H circuit. Let's say the capac. in the S/H is charged to e.g. 2V (from a previously measured analog pin or from an internal circuit like itself
  the S/H). In this case because the selected analog pin is floating you will measure something proportional with the previous measurement. Typically, if you have 8 analog inputs and the first is connected to 2.5V and the others are floating, you will get something like this (AD0-7, 8bit mode): 128,100,80,70,60,50,45,42 (the S/H capacitance discharges exponentially).
 I always use a big pulldown resistor (e.g. 100k) on analog inputs not only for set the undriven inputs into a definite state but to give chance to S/H circuit to discharge the capacitor over these resistors.
 :=I'm still in trouble with adc function of 16F877A.I am using port A0,A1,A5,E0,E1,E2.When i measure voltage between ports and GND they are usually at 1 milivolt or 2 milivolts.But when i log them adc function returns 100-120 values equals to 2.0V - 2.5V.When i measure E2 it gives 50 milivolt when i dont apply voltage on it(when idle i mean)!! My device does not work properly now please help!!
 :=No_Fear
 :=My code :
 :=#include <16F877A.h>
 :=#device adc=8
 :=#use delay(clock=4000000)
 :=#fuses XT, NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP
 :=#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7)
 :=void main() {
 :=int v1,v2,v3,v4,v5,v6;
 :=char ON;
 :=   setup_adc_ports(ALL_ANALOG);
 :=   setup_adc(ADC_CLOCK_INTERNAL);
 :=   setup_psp(PSP_DISABLED);
 :=   setup_spi(FALSE);
 :=   setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
 :=   setup_timer_1(T1_DISABLED);
 :=   setup_timer_2(T2_DISABLED,0,1);
 :=   setup_comparator(NC_NC_NC_NC);
 :=   setup_vref(FALSE);
 :=   set_tris_d(0x00);
 :=ON = 1;
 :=printf("3A75D5FA\r\n");
 :=while (1)
 := delay_ms(500);
 := set_adc_channel( 0 );delay_us(100);v1 = read_adc();delay_us(100);
 := set_adc_channel( 1 );delay_us(100);v2 = read_adc();delay_us(100);
 := set_adc_channel( 4 );delay_us(100);v3 = read_adc();delay_us(100);
 := set_adc_channel( 5 );delay_us(100);v4 = read_adc();delay_us(100);
 := set_adc_channel( 6 );delay_us(100);v5 = read_adc();delay_us(100);
 := set_adc_channel( 7 );delay_us(100);v6 = read_adc();delay_us(100);
 := printf("Value:\%2X/\%2X/\%2X/\%2X/\%2X/\%2X!",v1,v2,v3,v4,v5,v6);
 := if (ON == 1) {output_high(PIN_D2);ON = 0;} else {output_low(PIN_D2);ON = 1;}
 := v1=0;v2=0;v3=0;v4=0;v5=0;v6=0;
 :=I upload schematic at www.mcu.cz/atm
 :=Follow Home->Schematics->877.gif
 :=Please Helpp!!</font>
 Original Post ID: 144515029
		| No_Fear Guest
				|  Posted: Wed Jun 04, 2003 4:16 pm |   |
				| Hi,
 I fixed my problem.I remove 100 ohms resistors and zenner diodes and i connect 100 nf cap between gnd and every analog ch.An i connect 2.2 Kohms res. parallelly to capacitors.Now it works well.Thank you.
 No_Fear
 :=Do you have any analog voltage on any input pin?
 :=Don't forget that the PIC has only one A/D converter. The analog inputs are multiplexed. After the multiplexer there is a S/H circuit. Let's say the capac. in the S/H is charged to e.g. 2V (from a previously measured analog pin or from an internal circuit like itself <img src="http://www.ccsinfo.com/pix/forum/smile.gif" border="0"> the S/H). In this case because the selected analog pin is floating you will measure something proportional with the previous measurement.
 :=Typically, if you have 8 analog inputs and the first is connected to 2.5V and the others are floating, you will get something like this (AD0-7, 8bit mode): 128,100,80,70,60,50,45,42 (the S/H capacitance discharges exponentially).
 :=I always use a big pulldown resistor (e.g. 100k) on analog inputs not only for set the undriven inputs into a definite state but to give chance to S/H circuit to discharge the capacitor over these resistors.
 :=:=I'm still in trouble with adc function of 16F877A.I am using port A0,A1,A5,E0,E1,E2.When i measure voltage between ports and GND they are usually at 1 milivolt or 2 milivolts.But when i log them adc function returns 100-120 values equals to 2.0V - 2.5V.When i measure E2 it gives 50 milivolt when i dont apply voltage on it(when idle i mean)!! My device does not work properly now please help!!
 :=:=No_Fear
 :=:=My code :
 :=:=#include <16F877A.h>
 :=:=#device adc=8
 :=:=#use delay(clock=4000000)
 :=:=#fuses XT, NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP
 :=:=#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7)
 :=:=void main() {
 :=:=int v1,v2,v3,v4,v5,v6;
 :=:=char ON;
 :=:=   setup_adc_ports(ALL_ANALOG);
 :=:=   setup_adc(ADC_CLOCK_INTERNAL);
 :=:=   setup_psp(PSP_DISABLED);
 :=:=   setup_spi(FALSE);
 :=:=   setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
 :=:=   setup_timer_1(T1_DISABLED);
 :=:=   setup_timer_2(T2_DISABLED,0,1);
 :=:=   setup_comparator(NC_NC_NC_NC);
 :=:=   setup_vref(FALSE);
 :=:=   set_tris_d(0x00);
 :=:=ON = 1;
 :=:=printf("3A75D5FA\r\n");
 :=:=while (1)
 :=:= delay_ms(500);
 :=:= set_adc_channel( 0 );delay_us(100);v1 = read_adc();delay_us(100);
 :=:= set_adc_channel( 1 );delay_us(100);v2 = read_adc();delay_us(100);
 :=:= set_adc_channel( 4 );delay_us(100);v3 = read_adc();delay_us(100);
 :=:= set_adc_channel( 5 );delay_us(100);v4 = read_adc();delay_us(100);
 :=:= set_adc_channel( 6 );delay_us(100);v5 = read_adc();delay_us(100);
 :=:= set_adc_channel( 7 );delay_us(100);v6 = read_adc();delay_us(100);
 :=:= printf("Value:\%2X/\%2X/\%2X/\%2X/\%2X/\%2X!",v1,v2,v3,v4,v5,v6);
 :=:= if (ON == 1) {output_high(PIN_D2);ON = 0;} else {output_low(PIN_D2);ON = 1;}
 :=:= v1=0;v2=0;v3=0;v4=0;v5=0;v6=0;
 :=:=I upload schematic at www.mcu.cz/atm
 :=:=Follow Home->Schematics->877.gif
 :=:=Please Helpp!!</font>
 Original Post ID: 144515040
 | You cannot post new topics in this forum You cannot reply to topics in this forum
