anilmanisingh
| Unable to increment using push button |
Posted: Thu Mar 05, 2015 4:01 am |
#include <12F675.h>
//#device ADC=10
#fuses INTRC_IO,NOWDT,NOPUT,NOPROTECT,NOCPD,NOMCLR
#define GP0 PIN_A0
#define GP1 PIN_A1
#define GP2 PIN_A2
#define GP3 PIN_A3
#define GP4 PIN_A4
#define GP5 PIN_A5
int seq=0;
void blink_seq(void)
switch(seq)
case 0:
output_high( GP1 ); // turn LED on
delay_ms( 450 ); // wait 150ms
output_low( GP1 ); // turn LED off
case 1:
delay_ms( 300 ); // wait 150ms
case 2:
delay_ms( 150 ); // wait 150ms
if(!input(GP5))
seq++;
blink_seq();
Hello Everyone
I want the push button to change the case each time I press the button.
But it happens in three or fourth attempt.
Please help me to overcome this problem.
Last edited by anilmanisingh on Thu Mar 05, 2015 5:46 am; edited 1 time in total |
Mike Walne
Posted: Thu Mar 05, 2015 4:57 am |
Learn to use the code button, preserves your code layout and makes it more readable.
My compiler complains button1 is not defined and to your 'if/else if' in the push_button() routine.
So, I can't run your code.
What is supposed to happen as your variable seq advances beyond 2?
Mike |
oxo
Posted: Thu Mar 05, 2015 5:01 am |
| Code: | #include <12F675.h>
//#device ADC=10
#define GP0 PIN_A0
#define GP1 PIN_A1
#define GP2 PIN_A2
#define GP3 PIN_A3
#define GP4 PIN_A4
#define GP5 PIN_A5
int seq=0;
int count;
Void Push_Button()
static int1 pushed = false;
if (!pushed && !button1) // Pressed
pushed = true;
if (++count > 4)
count = 1;
if (button1) // Released
pushed = false;
switch(seq)
case 0:
case 1:
case 2:
Push_button();
//if(!input(GP5))
seq++;
blink_seq();
oxo
Posted: Thu Mar 05, 2015 5:06 am |
Lots of errors, As Mike said, the issue is seq, which will be incrementing very quickly in the main loop.
I would have thought seq should be incremented by the validated button press. |
anilmanisingh
Posted: Thu Mar 05, 2015 5:50 am |
Thanks for your reply.
Actually I want to blink led differently each time I press the push button GP5.
My problem is I am unable to get it correctly.
Hi mike after 2 I want to start over gain from zero and continue unless i cut off the supply .
Also I have seen one off you post like below and I want to do the same.
As I understand it, what you want is:-
(1) Operate in mode1 till button pressed, then advance to mode2.
(2) Operate in mode2 till button pressed, then advance to mode3.
(3) Operate in mode3 till button pressed, then return to mode1.
Thanks for you comment.
Please have a look at the new code:
#include <12F675.h>
//#device ADC=10
#define GP0 PIN_A0
#define GP1 PIN_A1
#define GP2 PIN_A2
#define GP3 PIN_A3
#define GP4 PIN_A4
#define GP5 PIN_A5
int seq=0;
switch(seq)
case 0:
case 1:
case 2:
if(!input(GP5))
seq++;
blink_seq();
http://imageshack.com/a/img540/7086/NAT6IY.png
https://imageshack.com/i/f0NAT6IYp
Last edited by anilmanisingh on Thu Mar 05, 2015 6:46 am; edited 2 times in total |
oxo
Posted: Thu Mar 05, 2015 6:01 am |
| If you can't be bothered to used the code button, I can't be bothered to read your code. I already formatted it for you once. |
Mike Walne
Posted: Thu Mar 05, 2015 6:49 am |
You're another one editing code after you've had a response.
Then makes nonsense of our replies.
In your original code (which oxo very kindly and neatly formatted for you) there was a variable count which more or less did what you want seq to do.
You've edited that code so our comments are no longer valid.
I've glanced at your new code (that's all I'm prepared to do) and notice your push_button() routine has gone.
Produce something which handles your buttons, use the "code button", then someone will be able to help you.
Mike |
Posted: Thu Mar 05, 2015 6:31 pm |
There are many ways to debounce a push-button. The program below
shows one way. Every time you push the button, you will increment the
count and it will be displayed in the terminal window (TeraTerm).
Example:
| Quote: | | 1 2 3 4 5 6 7 8 9 10 11 12 13 |
The push-button must be connected to the PIC with the circuit shown
below. You can use 4.7K pullup (or 10K or some other value).
+5v
> 4.7K
< ___ Push button switch
To | _|_|_
PIC -----------------o o------
pin |
B0 --- GND
In the test program below, the internal PortB pullups are used, so the
external pull-up is not needed.
Test program:
#include <18F4520.h>
#fuses INTRC_IO, BROWNOUT, PUT, NOWDT
#use delay(clock=4M)
#define BUTTON_PIN PIN_B0 // This pin must have a pull-up.
#define DEBOUNCE_PERIOD_IN_MS 10
#define DEBOUNCE_COUNT 2
void wait_for_keypress(void);
int8 count;
port_b_pullups(TRUE);
count = 0;
wait_for_keypress();
count++;
printf( "%u ", count);
char count;
// First, wait for the button to be released. With the debounce
// values as given above, the button must be in the "up" state
// for two consecutive readings, spaced 10 ms apart.
count = 0;
if(input(BUTTON_PIN) == 1)
count++;
count = 0;
if(count == DEBOUNCE_COUNT)
delay_ms(DEBOUNCE_PERIOD_IN_MS);
// Now that the button is up, wait until the user presses it.
// In order for the keypress to be considered valid, based
// on the debounce values listed at the beginning of the
// program, the button must be held down for two consecutive
// readings, spaced 10 ms apart.
count = 0;
if(input(BUTTON_PIN) == 0)
count++;
count = 0;
