Hex to decimal to character string conversion
Patrick OKeefe
PostPosted: Sat Nov 10, 2001 5:20 pm     Reply with quote
I need to convert a 32 bit hexidecimal integer to decimal, and then to a string of characters that represent the decimal conversion to output to the LCD routine lcd.c in the PICC examples. Anyone ever accomplish this?
Any hints appreciated.
Thanks,
Pat O'Keefe
Original Post ID: 1048
Tomi
Re: Hex to decimal to character string conversion
PostPosted: Sun Nov 11, 2001 9:40 am     Reply with quote
I assume that you are talking about a string contains hex data.
In this case you can use a modified version of the gethex() function in "input.c":
byte gethex1(char digit) {
if(digit<='9')
return(digit-'0');
return((toupper(digit)-'A')+10);
int32 gethex(char *inputString) {
int32 retval;
#byte retvalL = retval
#byte retvalH = retval+1
#byte retvalHL = retval+2
#byte retvalHH = retval+3
retvalHH = gethex1(inputString[0]);
retvalHH <<=4;
retvalHH += gethex1(inputString[1]);
retvalHL = gethex1(inputString[2]);
retvalHL <<=4;
retvalHL += gethex1(inputString[3]);
retvalH = gethex1(inputString[4]);
retvalH <<=4;
retvalH += gethex1(inputString[5]);
retvalL = gethex1(inputString[6]);
retvalL <<=4;
retvalL += gethex1(inputString[7]);
return(retval);
main()
int32 lResult;
char toConvert[9];
strcpy(toConvert,"1234ABCD"); // fill out the sample string
lResult = gethex(toConvert); // convert the string
printf(LCD_PUTC,"\%lu",lResult); // write it as decimal
:=I need to convert a 32 bit hexidecimal integer to decimal, and then to a string of characters that represent the decimal conversion to output to the LCD routine lcd.c in the PICC examples. Anyone ever accomplish this?
:=Any hints appreciated.
:=Thanks,
:=Pat O'Keefe
Original Post ID: 1054
Charlie U
PostPosted: Sun Nov 11, 2001 9:17 pm     Reply with quote
:=Thanks,
:=Pat O'Keefe
Pat,
You can use the printf() function to do this. Check the manual and the help.
Original Post ID: 1059
