HSM-20S Relative Humidity Temperature Sensor Demo
Post new topic   Reply to topic    CCS Forum Index -> Code Library
sshahryiar
PostPosted: Sun Nov 23, 2014 10:10 am     Reply with quote
#include <16F877A.h>
#device *= 16
#device ADC = 10
#fuses NOWDT, PROTECT, CPD, NOLVP, HS
#fuses NOBROWNOUT, NODEBUG, NOWRT, PUT
#use delay (clock = 10MHz)
#include "lcd.c"
const unsigned char symbol[8] = {0x00 ,0x0E, 0x0A ,0x0E, 0x00, 0x00, 0x00, 0x00};
void setup();
void lcd_symbols();
void get_parameters(float *relative_humidity, float *temperature);
   float t = 0;
   float rh = 0;
   setup();
      get_parameters(&rh, &t);
      lcd_gotoxy(9, 1);
      printf(lcd_putc, "%3.2g  ", rh);
      lcd_gotoxy(9, 2);
      printf(lcd_putc, "%3.2g  ", t);
void setup()
   disable_interrupts(global);
   setup_timer_0(T0_internal);
   setup_timer_1(T1_disabled);
   setup_timer_2(T2_disabled, 255, 1);
   set_timer0(0);
   set_timer1(0);
   set_timer2(0);
   setup_CCP1(CCP_off);
   setup_CCP2(CCP_off);
   setup_psp(PSP_disabled);
   setup_SPI(SPI_disabled);
   port_B_pullups(FALSE);
   setup_ADC(ADC_clock_internal);
   set_analog_pins(AN0_AN1_AN3);
   lcd_init();
   lcd_symbols();
   lcd_putc("\f");
   lcd_gotoxy(3, 1);
   lcd_putc("RH/%:");
   lcd_gotoxy(3, 2);
   lcd_putc("T/ C:");
   lcd_gotoxy(5, 2);
   lcd_putc(0);
void lcd_symbols()
   unsigned char s = 0;
   lcd_send_byte(0, 0x40);
   for(s = 0; s < 8; s++)
        lcd_send_byte(1, symbol[s]);
   lcd_send_byte(0, 0x80);
   unsigned long samples = 256;
   register unsigned long long avg_rh = 0;
   register unsigned long long avg_t = 0;
   while(samples > 0)
      set_ADC_channel(0);
      delay_ms(1);
      read_adc(adc_start_only);
      while(adc_done() == 0);
      avg_rh += read_adc(adc_read_only);
      set_ADC_channel(1);
      delay_ms(1);
      avg_t += read_adc(adc_read_only);
      samples--;
   avg_rh >>= 8;
   avg_t >>= 8;
   *relative_humidity = ((0.1507 * avg_rh) - 11.4378);
   *temperature = ((-0.0002 * avg_t * avg_t) + (avg_t * 0.2268) - 11.4945);
https://www.facebook.com/MicroArena
SShahryiar
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
