sshahryiar
Joined: 05 May 2010 Posts: 94 Location: Dhaka, Bangladesh
| Library for MAX7219 and MAX7221 SPI LED Display Driver IC |
Posted: Sat Nov 29, 2014 11:28 am |
MAX72xx.h
#define DIN pin_A1
#define CS pin_A2
#define CLK pin_A4
#define NOP 0x00
#define DIG0 0x01
#define DIG1 0x02
#define DIG2 0x03
#define DIG3 0x04
#define DIG4 0x05
#define DIG5 0x06
#define DIG6 0x07
#define DIG7 0x08
#define decode_mode_reg 0x09
#define intensity_reg 0x0A
#define scan_limit_reg 0x0B
#define shutdown_reg 0x0C
#define display_test_reg 0x0F
#define shutdown_cmd 0x00
#define run_cmd 0x01
#define no_test_cmd 0x00
#define test_cmd 0x01
#define digit_0_only 0x00
#define digit_0_to_1 0x01
#define digit_0_to_2 0x02
#define digit_0_to_3 0x03
#define digit_0_to_4 0x04
#define digit_0_to_5 0x05
#define digit_0_to_6 0x06
#define digit_0_to_7 0x07
#define No_decode_for_all 0x00
#define Code_B_decode_digit_0 0x01
#define Code_B_decode_digit_0_to_3 0x0F
#define Code_B_decode_for_all 0xFF
void MAX72xx_init();
void MAX72xx_write(unsigned char address, unsigned char value);
MAX72xx.c
#include "MAX72xx.h"
void MAX72xx_init()
output_high(CS);
MAX72xx_write(shutdown_reg, run_cmd);
MAX72xx_write(decode_mode_reg, No_decode_for_all);
MAX72xx_write(scan_limit_reg, digit_0_to_7);
MAX72xx_write(intensity_reg, 0x04);
MAX72xx_write(display_test_reg, test_cmd);
MAX72xx_write(display_test_reg, no_test_cmd);
unsigned char s = 0;
unsigned long data_word = 0;
data_word = (((unsigned long)address << 8) | value);
output_low(CS);
for(s = 0; s < 16; s += 1)
if((data_word & 0x8000) != 0)
output_high(DIN);
output_low(DIN);
output_low(CLK);
delay_ms(1);
output_high(CLK);
data_word <<= 1;
output_high(CS);
_________________ https://www.facebook.com/MicroArena
SShahryiar |
tedibear
| gggg |
Posted: Tue Mar 03, 2015 2:05 am |
Rica etsem örnek bir kod yazmanız mümkün mü?
Is it possible to write a sample code please? _________________ Nawaz |
sshahryiar
| Sample code |
Posted: Tue Mar 03, 2015 2:37 am |
#include <12F675.h>
#device *=16
#device ADC = 8
#fuses INTRC_IO, PROTECT, CPD, PUT, NOBROWNOUT, NOWDT, NOMCLR
#use delay (internal=4MHz)
#define tilt_switch !input(pin_A3)
#include <stdlib.h>
#include "MAX72xx.c"
const unsigned char disp[56] =
0x00, 0x00, 0x00, 0x18, 0x18, 0x00, 0x00, 0x00,
0xC0, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x03, 0x03,
0xC0, 0xC0, 0x00, 0x18, 0x18, 0x00, 0x03, 0x03,
0xC3, 0xC3, 0x00, 0x00, 0x00, 0x00, 0xC3, 0xC3,
0xC3, 0xC3, 0x00, 0x18, 0x18, 0x00, 0xC3, 0xC3,
0xDB, 0xDB, 0x00, 0x00, 0x00, 0x00, 0xDB, 0xDB,
0x81, 0x42, 0x24, 0x18, 0x18, 0x24, 0x42, 0x81
void setup();
unsigned char i = 0;
unsigned long j = 0; ;
unsigned char disp_adj = 0;
setup();
read_adc(adc_start_only);
while(!adc_done());
disp_adj = read_adc(adc_read_only);
disp_adj >>= 4;
MAX72xx_write(intensity_reg, disp_adj);
if(tilt_switch)
for(i = 0; i < 8; i++)
MAX72xx_write((i + 1), 0x00);
while(tilt_switch)
j = rand();
j /= 4681;
MAX72xx_write((i + 1), disp[((j << 3) + i)]);
void setup()
disable_interrupts(global);
setup_ADC(ADC_clock_internal);
setup_ADC_ports(sAN0);
set_ADC_channel(0);
setup_timer_0(T0_internal);
setup_timer_1(T1_disabled);
set_timer0(0);
set_timer1(0);
MAX72xx_init();
SShahryiar |
