Incorrect Rom matrix readings
CMatic
PostPosted: Sat Nov 29, 2014 10:27 pm     Reply with quote
Implementing a menu using structures in PIC16F1825. The values when read from the array elements the values are incorrect. Example, when menu[0].text is read it does show the text string. However when I test for num_menu or any other values, it shows nothing, frustrated me for last two nights....thanks
Compiler Version 5.026
static int num_menu, UP, DOWN, ENTER, default_value;
static typedef struct MenuEntry {
   char text[14];
   char num_menu;
   char UP;
   char DOWN;
   char ENTER;
   int16 *funct_ptr;
   int default_value;
void show_menu(void);
void browse_menu(void);
void testfun(void);
unsigned char selected = 1;
//unsigned int16 *pMenu;
rom int *pMenu;
rom struct MenuEntry menu[] = {
   {"[Main]"  ,5,0,0,0,0,0},
   {"Option1",5,1,2,0,&testfun,1},
   {"Option2",5,0,0,0,6,2},
   {"Option3",5,0,0,0,0,3},
   {"Option4",5,0,0,0,0,4},
   {"[Sub]"   ,5,0,0,0,0,5},
   {"Option1",5,0,0,0,0,6},
   {"Option2",5,0,0,0,0,7},
   {"Option3",5,0,0,0,0,8},
   {"Option4",5,0,0,0,0,9}
pMenu = &menu;
