cootemca
| PIC18F4550 sending data to the PC |
Posted: Wed Jul 30, 2014 8:55 pm |
| Good evening, my question is, how to make a program sending data from PIC18F4550 to a PC. Please show me an example. |
Posted: Wed Jul 30, 2014 10:36 pm |
#include <18F4550.h>
#fuses INTRC_IO, NOWDT, PUT, BROWNOUT, NOLVP
printf("Hello World\n\r");
Posted: Thu Jul 31, 2014 1:16 am |
I suspect he might be wanting to use USB (since he is using the 4550). So perhaps ex_usb_serial.c |
cootemca
| Send data from PIC to PC with PIC18F4550 |
Posted: Thu Jul 31, 2014 8:55 pm |
You're absolutely right, the idea is to use usb_put_packet() and send data
byte by byte. |
Posted: Fri Aug 01, 2014 12:57 am |
| You don't need to fiddle with put_packet. As I said, look at ex_usb_serial (and the other versions). These generate a CDC device, and send the data byte by byte, but buffer this through usb_putc/getc, so you can simply printf a message and it is all sent for you. |
