art
| Convert 74165 decimal result to Binary |
Posted: Mon Dec 12, 2016 7:19 pm |
I've build a program to get result from 8 input push button using 74165 shift register.
The program works well. However the result is in decimal (0~127, -1 ~ -128).
I would like to get the result in binary number such as 11111111 instead of (-128).
Hope someone can help me to solve this problem
#include <18F4550.h>
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN
#use delay(clock=48000000)
#include <string.h>
#include <input.c>
#include <stdio.h>
#include <stdlib.h>
#include <usb_cdc.h>
#include <74165.c>
char c;
int8 data ;
unsigned char d;
unsigned char key;
usb_init_cs();
while (TRUE)
usb_task();
if (usb_cdc_kbhit())
c=usb_cdc_getc();
if (c=='\n') {putc('\r'); putc('\n');}
if (c=='\r') {putc('\r'); putc('\n');}
while(true)
d = usb_cdc_getc();
if(d=='U') // push W
while (key!=32) // push SPACE BAR to stop
if(usb_cdc_kbhit())
{key=usb_cdc_getc();}
read_expanded_inputs(&data);
printf(usb_cdc_putc,"\r%d ", data);
} key=0;
art
Posted: Mon Dec 12, 2016 9:27 pm |
Hi PCM,
Thanks for the idea.
I've change my code and it works as I plan
#DEVICE ADC=10
#fuses HSPLL,NOWDT,PROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN
#include <string.h>
#include <input.c>
#include <stdio.h>
#include <stdlib.h>
#include <74165.c>
char c;
int8 data ;
unsigned char d;
unsigned char key;
usb_init_cs();
while (TRUE)
usb_task();
c=usb_cdc_getc();
while(true)
d = usb_cdc_getc();
if(usb_cdc_kbhit())
delay_us(5);
if(bit_test(data,0)) // 1
m1=1;
m1=0;
if(bit_test(data,1)) //2
m2=1;
m2=0;
if(bit_test(data,2)) //3
m3=1;
m3=0;
if(bit_test(data,3)) //4
m4=1;
m4=0;
if(bit_test(data,4)) // 5
m5=1;
m5=0;
if(bit_test(data,5)) //6
m6=1;
m6=0;
if(bit_test(data,6)) //7
m7=1;
m7=0;
if(bit_test(data,7)) //8
m8=1;
m8=0;
printf(usb_cdc_putc,"\r%d%d%d%d%d%d%d%d ", m1,m2,m3,m4,m5,m6,m7,m8);
} key=0;
art
Posted: Mon Dec 12, 2016 9:29 pm |
| Do you have ideas to simplify the code? |
Posted: Mon Dec 12, 2016 11:03 pm |
Your code uses a programming technique called "unrolling a loop".
You could make it into a for() loop. |
