Example DMA code for the DsPIC33
Post new topic   Reply to topic    CCS Forum Index -> Code Library
dyeatman
PostPosted: Fri Jul 11, 2014 4:23 pm     Reply with quote
Written using CCS PCD Version 5.026 for the DsPIC Processor
After this code starts it blinks an LED on Pin E1 at 1Hz and waits for eight
consecutive characters to arrive via UART1 then prints them on the
terminal. If this simple code doesn't work in hardware with the above
version you have a hardware problem. It is NOT designed to be used in
Proteus!!
#include <33FJ256MC710.h>
#FUSES XT
#FUSES NOWDT                  //No Watch Dog Timer
#FUSES PUT128                 //Power On Reset Timer value 128ms
#device ICSP=1
#use delay(internal=16MHZ)
#use rs232(baud=9600, UART1,bits=8,parity=N)//
#BANK_DMA
    char UARTBUFF[8];
#INT_DMA0
void DMA0_ISR(void)
   int i;
   printf("Buffer= ");
   for(i=0;i<8;++i)
       printf("%c", UARTBUFF[i]);
   printf("\r\n\n");
/////////// Begin Main /////////////
   setup_ADC_PORTS(NO_ANALOGS);// make sure they dont interfere if we dont need them
   setup_dma(0, DMA_IN_UART1, DMA_BYTE);
   dma_start(0, DMA_CONTINOUS, UARTBUFF);
   enable_interrupts(INT_DMA0);      //enable DMA interrupt
   enable_interrupts(GLOBAL);       //enable interrupts
For(;;)
  { ///////// main loop /////////////////////
    output_toggle(pin_E1); // verify the chip is running and at the right speed
    delay_ms(500);  // led should blink at 1Hz
}  // end Main Routine
Google and Forum Search are some of your best tools
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
