		| View previous topic :: View next topic   |
			noral
				| LCD Menu problems |
				 Posted: Fri Jun 20, 2014 2:41 am     |
				Hi everyone!!
I'm developing a user's menu with two buttons to introduce a value. To reach my goal I use a increaser counter from 0 to 9 to introduce the hundreds in "MENU2" and the tens in "MENU3". With the left button I increase the number and with right button I want to move the cursor to introduce the tens.
My issue is that I can't pass from the "MENU2" to "MENU3".
Can anybody help me? I attach the code.
#include <24FJ128GC010.H>
#device adc=12
#fuses FRC, NOWDT, NOPROTECT, BROWNOUT, ICSP1
#use delay(clock = 8000000)
#include <flex_lcd.c>
#define ledrojo PIN_E0
#define ledverde PIN_E1
#define botonder PIN_E2
#define botonizq PIN_E3
#define buzzer PIN_E4
int boton;
float tension;
signed int32 read;
int menu=1;
int i=0;
char tabNum[10]={'0','1','2','3','4','5','6','7','8','9'},j=0;
int mov[10];
int centenas;
int decenas;
int unidades;
void configurar(void);
    disable_interrupts(GLOBAL);
    setup_oscillator(OSC_INTERNAL,8000000);
    output_low(ledrojo);
    output_low(ledverde);
    output_low(buzzer);
    lcd_init();
    lcd_gotoxy(1,1);
    printf(lcd_putc,"\fLISTO!");
    printf(lcd_putc,"\n");
    delay_ms(1500);
    printf(lcd_putc,"\f");
    delay_ms(750);
        if(input(botonder)==1){ //boton
            delay_ms(30);
            output_toggle(PIN_E0); //salida led
            output_toggle(PIN_E1); //salida led
            configurar();
            menu++;
            if (menu==7){
                menu=1;
                delay_ms(30);
            while(input(botonder)==1);
void configurar()
    switch (menu)
        case 1:menu=1;
            printf(lcd_putc, "\f");
            printf(lcd_putc, "\n          INICIO");
        case 2: menu=2;
            printf(lcd_putc, "\fMENU2:");
            printf(lcd_putc, "\n             -->");
            while(menu=2){
                if(input(botonizq)){
                        do{
                        }while(input(botonizq));
                        delay_ms(75);
                        if(j>9){
                            j=0;
                            output_high(buzzer);
                            delay_ms(50);
                            output_low(buzzer);
                         lcd_gotoxy(1,2);
                         printf(lcd_putc,"%c",tabNum[j]);
                         printf(lcd_putc,"\b");
                         j++;
                         //incremento contador indice tabNum
                    menu=3;
        centenas=j*100;
        case 3: menu=3;
            printf(lcd_putc, "\fMENU3:");
            while (menu==3){
                if(!input(botonizq)){
                    do{
                    }while(!input(botonizq));
                        if(j>9){
                        j=0;
                        delay_ms(50);
                        output_low(buzzer);
                    lcd_gotoxy(2,2);
                    printf(lcd_putc,"a");
                    //printf(lcd_putc,"\b");
                    j++;
            decenas=j*10;
			Mike Walne
				 Posted: Fri Jun 20, 2014 4:46 am     |
				Take a step back.
Work out what you want to happen with pencil and paper.
Draw a picture of what you want to see at each stage.
It should fall out.
Mike |
			RF_Developer
				 Posted: Fri Jun 20, 2014 5:26 am     |
				 	  | Mike Walne wrote: | 	 		  Take a step back.
It should fall out. |
Also think strongly about separating the functions: button handling/debouncing, and menu processing. Its simpler to do and involves less repeated code than trying to do it all in one hit.
I had a similar sort of problem on a ARM based product with just two user buttons. I wrote a button press handler that did all the button stuff, and a table driven menu handler which implemented the menu functions. One button was for moving from item to item in the menus, the other was for selecting the menu item. I could have several levels of menus, all defined by the table.  So it was left press, press to get to an item/sub-menu, right press to select it, left press to traverse the sub-menu, right press to select, etc. |
