Please help on GLCD 128x64
prakasit_man
PostPosted: Sat Jun 07, 2014 12:32 pm     Reply with quote
Dear Sir,
Would you please advise me the proper library/ source code to use with?
I am using PIC16F877A with GLCD 128x64, S6B0108 controller.
I tried to use library HDM64GS12.c but it did not work properly.
My compiler version pcwhdupd 5-0008
Here is my GLCD specification.
http://www.es.co.th/detail.asp?prod=40100201
http://www.es.co.th/Schemetic/PDF/ABG128064A15-BIW.PDF
I also upload the result after use HDM64GS12.c; here is link
Thank you in advance.
Regards
Prakasit
PostPosted: Sat Jun 07, 2014 1:56 pm     Reply with quote
Have you searched the forum for S6B0108 and KS0108B?
There is a lot of entries on this forum for the KS0108 and
four for the S6B0108.
I originally used HDM64GS12.c on the DsPIC and it worked for me with no
problems, so apparently you have issues that must be fixed. It will take
some work on your part.
Here is someone who got it to work properly using HDM64GS12.c:
http://www.ccsinfo.com/forum/viewtopic.php?p=70011
As I said earlier I have used HDM64GS12.c However, to add functionality I
downloaded and converted the DIGOLE library to use the
PIC133FJ256MC710, so there are other options out
there if you want to put in some time and effort.
