MPLAB X Unable to Resolve Identifier
mictel
PostPosted: Sat May 24, 2014 7:32 am     Reply with quote
New to MPLAB X Version 2.10. Using PCM Version 5.062. Created a project from a project that works just fine in MPLAB V8.92. Installed the CCS C plug in, program compiles successfully with no errors but...
MPLAB X flags pin variable Disp1 as "Unable to resolve identifier".
For example:
#bit Disp1 = port_c.0
Disp1 = 1; Gets flagged in most but not all places in the code with the warning "Unable to resolve identifier Disp1" and Disp1; is underlined in RED
But pin variable CapTestLED defined the exact same way:
#bit CapTestLED = port_b.3
CapTestLED = 0; Is not flagged anywhere so what the heck is MPLAB X complaining about?
Also have the same problem for standard variables like INT_Timer1 as in this example:
disable_interrupts(INT_Timer1);
Get the MPLAB X error: Unable to resolve identifier INT_Timer1
Searched but did not see this addressed. Thanks for the help.
PostPosted: Sat May 24, 2014 9:13 am     Reply with quote
Use Google. Search the Microchip forum for this:
"MPLAB X" " Unable to resolve identifier"
Get this:
http://www.microchip.com/forums/m775535.aspx
mictel
PostPosted: Sat May 24, 2014 12:32 pm     Reply with quote
Thank You!
