picj1984
Triggering an interrupt in firmware |
Posted: Sat May 10, 2014 12:24 pm |
Hi guys,
I feel silly asking this, but I'm spinning my wheels trying to figure out how to do it, and my searches have been fruitless. How do you trigger an interrupt in the code itself?
I'm thinking it is the opposite of the clear_interrupt() function.
Basically, I have a button that I press that triggers an external interrupt, and I'd like to be able to trigger it in code as well.
Thx |
stinky
Joined: 05 Mar 2012 Posts: 99 Location: Central Illinois
Posted: Sat May 10, 2014 1:42 pm |
You'll need to confirm in your data sheet if the interrupt flags you wish to access are writable. Assuming they are, you could map to the desired special function register.
However, why?
Are you saying that you'd like an external interrupt, and a branch of software to execute the same code? Seems like this is just a flow control issue. |
Joined: 01 Jul 2010 Posts: 9539 Location: Greensville,Ontario
Posted: Sat May 10, 2014 1:44 pm |
off the top of my head....if your program sets the appropriate interrupt flag bit of it's interrupt control register, that 'should' work....
I recall those bits are R-W types ....
I can't test though as I'm working on the D-14 tractor(higher priority interrupt !!)
hth
jay |
Mike Walne
Posted: Sat May 10, 2014 2:23 pm |
I just checked a random PIC data sheet.
Confirms Jay's suspicion, xxxIF's are R/W.
You will, of course, have to check the flag you want to use is indeed R/W.
Though you are not telling us why you should want/need to do it.
Mike |
Humberto
Posted: Sat May 10, 2014 6:20 pm |
I think you can do it, bearing in mind the previous comments and considerations stated.
Talking seriously, I can not imagine: for what reasons you have to do such test?
regards, _________________ Humber |
picj1984
Posted: Sat May 10, 2014 7:11 pm |
Now that I've actually thought it through... it doesn't make sense for me to do it this way. I appreciate the responses though! |
Posted: Sat May 10, 2014 9:46 pm |
One reason to do it, is part of a device 'self-calibration' routine where the 'external event' is needed to trigger the 'calibration routine'. Done this way the overall timing would be the same as 'real life'.
'event happens'
ISR is entered...
stuff done...
ISR is exited...
'calibration completed'.
hth
jay |
Battery David
Posted: Mon May 12, 2014 12:32 pm |
This is something I have been wondering. I have a customer who wants tests for every possible thing and I have ISRs for things like oscillator failure. How do you test for something like that? I'll just force the interrupt and trust that the hardware will set the bit automatically in case the oscillator actually does fail. |
Posted: Mon May 12, 2014 1:23 pm |
Quote: |
oscillator failure.
simple...
make a SHORT test program that toggles an LED , say 4x /second.
with your complete PIC fuse setup, using an external plug in crystal
or oscillator can.
then force the osc int failure by pulling out the crystal and watch to see the LED flash rate..
very crude - but a purely "hacker" way to see if it works -
but is just what i'd do  |
newguy
Posted: Mon May 12, 2014 4:18 pm |
Battery David wrote: | This is something I have been wondering. I have a customer who wants tests for every possible thing and I have ISRs for things like oscillator failure. How do you test for something like that? |
If your crystal is in a through hole package, I've found that simply touching the leads where they protrude on the bottom of the board is enough to cause the oscillator to fail. I'd imagine that touching the OSC pins on the processor would accomplish the same thing. |
Battery David
Posted: Tue May 13, 2014 10:21 am |
Sadly, I'm using the internal oscillator. |
RF_Developer
Posted: Tue May 13, 2014 10:25 am |
Battery David wrote: | Sadly, I'm using the internal oscillator. |
Then the PIC is dead in the water if it fails. No clock = no processing. Doesn't matter if it interrupts, it can't do anything. |
Posted: Tue May 13, 2014 11:13 am |
Yes.
You need to understand that the PIC needs a clock to run. Can't do anything if the clock is not running. What it has is a circuit to detect if an external oscillator is running, and if it isn't, if 'fail safe clock monitoring' is enabled, it switches to the internal oscillator, and sets the oscillator failure flag. Running on the internal oscillator there is no such fallback.
Posted: Tue May 13, 2014 7:51 pm |
One possible 'dead PIC' detector/display is to have the PIC trigger a 'retriggerable' one shot( 74123 ) every so often. If it fails to do so within the time allowed the oneshot turns on an LED. This does require an I/O pin,74123 and LED but does visually confirm the PIC has stopped.
Another 'philosophy' might be the POST(Power On Self Test) that PCs have had since day one.Before a 'test' is made a number is sent to say the LCD or LED unit. When it passes the test, the number is incremented and carries on...
if the unit fails a test, the number tells you which test failed.
depending on the PICs memory anything/everything could be tested...
just food for thought
hth
jay |
