[SOLVED] dsPIC33EP32MC202 rebooting
alan
PostPosted: Thu May 01, 2014 2:47 am     Reply with quote
Hi All,
CCS 5.019
Anybody got an idea why the following code will restart the MCU. It happens every 30sec.
#include <33EP32MC202.h>
#device ADC=10
#FUSES NOIESO                   //Internal External Switch Over mode disabled
#FUSES OSCIO                    //OSC2 is general purpose output
#FUSES NOCKSNOFSM                 //Clock Switching is disabled, fail Safe clock monitor is disabled
#FUSES NOWINDIS                 //Watch Dog Timer in Window mode
#device ICSP=2
//FRC = 7.37MHz so CLK_FREQ should be multiple of this
#use delay(internal=36850000)
#include <stdint.h>
#use fast_io(A)
#use fast_io(B)
#define LED PIN_A3
int16_t VinADC, LEDTime;
void main(void) {
  setup_adc(ADC_CLOCK_DIV_8|ADC_TAD_MUL_16);
  setup_adc_ports(sAN0 | sAN1, VSS_VDD );
  set_adc_channel(0);
  output_a(0);
  output_b(0);
  set_tris_a(0x03);
  set_tris_b(0x0281);
  //Toggle LED when reboot to check for PIC resetting
  //Happens randomly
  output_toggle(LED);
  output_toggle(LED);
  output_toggle(LED);
  output_toggle(LED);
  output_toggle(LED);
  while (TRUE) {
    if (LEDTime++ > 5000) {
      output_toggle(LED);
      LEDTime = 0;
    VinADC = read_adc() - 516;
Regards
alan
PostPosted: Thu May 01, 2014 3:44 am     Reply with quote
I left the ICD-U64 in after programming and somehow the programmer resetted the MCU every 30sec. When unplugged the board does not reset anymore.
Regards
