anitha
| Expecting close paren error |
Posted: Sat Mar 29, 2014 5:30 am |
#include <18F4550.h>
#device adc=10
#FUSES NOWDT, XT
#use delay(clock=12000000)
#include <math.h>
#include <lcd.c>
#define switchautomatic PIN_B0
#define switchmanual PIN_B1
#define switchGEN PIN_B2
#define switchbus pin_b3
#define switch400 pin_b4
#define switch230 pin_b5
#define switch110 pin_b6
#define outputrelay pin_d3
//#define ledauto pin_eo
#define led400 pin_e1
#define led230 pin_e2
#define led110 pin_a2
#define ledready pin_a3
#define lednotready pin_a5
#define vh1 420;
#define vl1 380;
#define vh2 245;
#define vl2 215;
#define vh3 120;
#define vl3 100;
#define fh 51;
#define fl 49;
#define dl 0;
#define dh 20;
int16 data3;
int16 data4;
float V3;
float V4;
float f3;
float f4;
long rise3,rise4,pulse_width;
float realpulse,phase2;
output_high(lednotready);
output_low(outputrelay);
setup_adc(ADC_CLOCK_INTERNAL); // initialize ADC with a sampling rate of Crystal/4 MHz
setup_adc_ports(ALL_ANALOG);
set_adc_channel(0); // point ADC to channel 0 for ADC reading
delay_ms(10);
data3 = read_adc(); // capture reading from sensor 1
delay_us(10); // 0.1ms delay for ADC stabilization
set_adc_channel(1); // point ADC to channel 0 for ADC reading
delay_ms(10);
data4 = read_adc(); // capture reading from sensor 2
V3=data3*0.439453;
V4=data4*0.439453;
lcd_gotoxy(1,1);
printf(lcd_putc,"%f kv",v3);
lcd_gotoxy(1,2);
printf(lcd_putc,"%f kv",v4);
if((input(switch400)==1) && (Vl1<V3)) ---->In this line indicating expecting close paren
//if(VL1<V3)
output_high(led400);
output_low(lednotready);
output_high(ledready);
output_high(outputrelay);
lcd_gotoxy(10,2);
printf(lcd_putc,"400 R");
if(input(switch230)==1)
//if(vl2<v3<vh2)
output_high(led230);
lcd_gotoxy(10,2);
printf(lcd_putc,"230 R");
if(input(switch110)==1)
//if(vl3<v3<vh3)
output_high(led110);
lcd_gotoxy(10,2);
printf(lcd_putc,"110 R");
Joined: 01 Jul 2010 Posts: 9627 Location: Greensville,Ontario
Posted: Sat Mar 29, 2014 5:54 am |
probable error is ...
#define vl1 380;
several lines above.
defines must not have ; (semicolons) at the end of the line.
It appears you added a few defines with semicolons, easy to do.
also these lines ..
aren't needed as you've delayed for 10ms just before you read the ADC.
recode/recompile/retest/report back
hth
jay |
Posted: Sat Mar 29, 2014 5:55 am |
So many things.....
Use the code buttons.
What is the fastest clock rate the XT oscillator supports?.
Get into the habit of using case. You declare variables in lower case, then use them in upper case.
Then the one that causes the problem vl1 and v11 are not the same.
Is ADC_CLOCK_INTERNAL recommended at 12MHz?.
What is the delay for after the ADC reading?. The ADC is not 'stabilising' at this point.
Generally avoid doing comparisons on float values.
As a comment use 'TRUE', rather than '1' in logic comparisons.
Gave up at this point. |
