Green20
| uart code |
Posted: Thu Mar 20, 2014 6:42 pm |
Hi all
please how can I write a code like that by the CCS compiler , I can't find an instruction equivalent to it
if (uart_available())
c1 = getchar();
ezflyr
Posted: Thu Mar 20, 2014 6:52 pm |
The kbhit() function will tell you if a character is available. If you are using the hardware UART it's probably better to just use the int_rda interrupt rather than polling to see if a character is available.
John |
Green20
Posted: Thu Mar 20, 2014 7:03 pm |
| Thank you sooo much |
Green20
Posted: Thu Mar 20, 2014 7:25 pm |
I'm sorry but please I need to clear a register but when I'm searching in the content of the CCS compiler I just found :
bit_clear(x,2);
so this clear only one bit of a register not all the content of it !!! |
newguy
Posted: Thu Mar 20, 2014 7:31 pm |
| x = 0; |
Green20
Posted: Thu Mar 20, 2014 7:41 pm |
thank you again  |
