I2C 18f2550 master received string - 16f1503 slave (SOLVED)
jartur32
PostPosted: Fri Mar 21, 2014 1:36 pm     Reply with quote
Hi all Very Happy
I'm having a problems when using I2C in one project.
In my project, I receive a data string from i2c master to slave perfect, but I can not send a request to return data from the master to the slave, which only need to return a string to the master pic. I've only gotten back a single character with no problem.
I used PIC18F2550 master and 16f1503 slave.
Thank so much !
Master send code 18f2550
#define SDA_PIN  PIN_B0
#define SCL_PIN  PIN_B1
#use I2C(MASTER, SDA=SDA_PIN, SCL=SCL_PIN, FORCE_HW, FAST)
#define lenbuff_buffer_i2c_incoming  10
char buffer_i2c_incoming[lenbuff_buffer_i2c_incoming];
i2c_start();                           // ATTENTION Slaves!
i2c_write(Slave_1_ADDR + 1);           // adding 1 to the address tells the slave that you will be reading data from it
buffer_i2c_incoming[0] = i2c_read(1);  // read data from the slave (a '1' is default and sends and ACK(acknowledge) to the slave upon successful
buffer_i2c_incoming[1] = i2c_read(1);  // read data from the slave (a '1' is default and sends and ACK(acknowledge) to the slave upon successful
buffer_i2c_incoming[2] = i2c_read(1);  // read data from the slave (a '1' is default and sends and ACK(acknowledge) to the slave upon successful
buffer_i2c_incoming[3] = i2c_read(1);  // read data from the slave (a '1' is default and sends and ACK(acknowledge) to the slave upon successful
buffer_i2c_incoming[4] = i2c_read(1);  // read data from the slave (a '1' is default and sends and ACK(acknowledge) to the slave upon successful
buffer_i2c_incoming[6] = i2c_read(0);  // a '0' tells the slave that reading time is over and the Master doesn't want any more data
i2c_stop();                            // release the bus
Slave received code 16f1503
#define SCL_i2c            PIN_C0
#define SDA_i2c            PIN_C1
#USE I2C(SLAVE, sda=SDA_i2c, scl=SCL_i2c, ADDRESS=0x10, FORCE_HW, FAST)
#define lenbuff_string_i2c_return  7
char string_i2c_return[lenbuff_string_i2c_return] = {'1','2','3','4','5','6','\0'};
#INT_SSP
void ssp_interrupt()
   char state,incoming;
   state = i2c_isr_state();
   if(state < 0x80)//Master send data
      incoming = i2c_read();//An array will be needed to store data if more than one byte is transferred
      if (state == 0)
         count_i2c_data = 0; //here need to read but not store
         string_i2c[count_i2c_data++] = incoming;
         if (incoming==0)
             FLAG_have_string=TRUE;
   if(state == 0x80)//Master need data
      for (int8 j = 0; j <= strlen(string_i2c_return); j++)  // for
         i2c_write(string_i2c_return[j]);                    // send actual data
PostPosted: Fri Mar 21, 2014 2:44 pm     Reply with quote
Are you aware that you have a previous, from Feb. 23, 2014, where you
ask the exact same question and Ttelmah solved it for you with sample
code, and you tested it and declared the problem solved ?
http://www.ccsinfo.com/forum/viewtopic.php?t=51961
jartur32
PostPosted: Fri Mar 21, 2014 3:11 pm     Reply with quote
hi pcm programmer
This is a new problem, I can not make the pic slave responds to the pic master with a string, and the pic-master receives the string data to show value on LCD. I've only gotten back a single character to the master. il change the topic name to one more correct and diferent
PostPosted: Fri Mar 21, 2014 3:24 pm     Reply with quote
Right, but in your new code here you are attempting to send the whole
string in one pass, inside the isr. Try it with the slave sending one byte
per #int_ssp interrupt.
Also, you are declaring locals inside the code. This isn't really supported
in CCS. I mean this:
for (int8 j = 0
You should declare locals at the start of the function.
jartur32
PostPosted: Sat Mar 22, 2014 6:58 pm     Reply with quote
Thank pcm programmer
Final code
Master
#define ADDR           0x10
#define lenbuff_i2c  6
char buffer_i2c[lenbuff_i2];
void read_i2c(void)
   i2c_write(ADDR);                 // address slave
   i2c_write(0x00);                 // address data 0
   i2c_write(ADDR + 1);             // Adding 1 to the address reading data
   buffer_i2c[0] = i2c_read(1);     // Read data from the slave
   buffer_i2c[1] = i2c_read(1);     // Read data from the slave
   buffer_i2c[2] = i2c_read(1);     // Read data from the slave
   buffer_i2c[3] = i2c_read(1);     // Read data from the slave
   buffer_i2c[4] = i2c_read(0);     // A '0' Master doesn't want any more    data
   buffer_i2c[5] = '\0';
   i2c_stop();
Slave
int8 j=0;
int1 FLAG_have_string = FALSE;
#define lenbuff_string_i2c  7
char string_i2c[lenbuff_string_i2c];
#define lenbuff_string_i2c_return  6
char string_i2c_return[lenbuff_string_i2c_return];
#INT_SSP
   if(state < 0x80)//Master envia datos
      if (state == 0)
         j = 0;
         if ( incoming == 0 )
   if(state >= 0x80)//Master pide datos
      i2c_write(string_i2c_return[j++]);                    // send actual data
