ICD-U64 debug won't work.... driver problem???
zombiePIC
PostPosted: Fri Feb 21, 2014 4:13 pm     Reply with quote
Hi guys.
I am wondering if anybody had the same problem as me....
[IMG]http://i.imgur.com/TZDBrUt.jpg?1[/IMG]
I think i may have messed up the driver because i previously installed this...
http://www.ebay.co.uk/itm/MAX232-RS232-To-TTL-Converter-Adapter-Module-Board-New-LONDON-CITY-UK-SELLER-/121277082424?ssPageName=ADME:L:OC:IE:3160
Anybody have ideas?? I tried deleting the drivers and reinstall (well i think i did anyway) Also i uninstalled ccsload.
I didn't touch the compiler...
PostPosted: Sat Feb 22, 2014 4:02 am     Reply with quote
It is not a driver problem. It is talking to the chip (08 response proves this). Is the oscillator configured right?. You have it set up to use a 20MHz external crystal. Is this what is connected to the chip?.
zombiePIC
PostPosted: Sat Feb 22, 2014 12:15 pm     Reply with quote
thanks for the help...
looks like a tiny piece of copper got stuck in between one of the components and fried the legs off of it...
thanks
PostPosted: Sat Feb 22, 2014 12:46 pm     Reply with quote
Ooops..... Crying or Very sad
gpsmikey
PostPosted: Sat Feb 22, 2014 3:18 pm     Reply with quote
Yeah, once you let the magic smoke out, you are done. Sad
mikey
mikey
