asd
| Modbus TCP multiple node communication*** Locked - off topic |
Posted: Thu Feb 06, 2014 8:15 pm |
Locked.
Reason: Visual C++ is off-topic on CCS C compiler for Microchip PIC
microcontrollers forum.
- Forum Moderator
I'm working on win ce 6 modbus tcp client server, application is developed for a client server communication and it is working fine. Now requirement is my slave device should respond to the different slave addresses polled by master/client. Can I just change slave id and establish connection or I need to close previous connection and again establish new one ?
Below is the code, which is working fine for one node. If I polled with other node ID then it gives exception. What change is required to communicate with other node simultaneously ? My device should be able to communicate with 32 different nodes on modbus tcp. Shall I create individual threads for each node ? But how will they communicate on same port? Before establishing connection with other node shall I close previous node?
startupServer(int slaveAddr, const TCHAR * const hostName)
int result;
int tcpOption;
struct sockaddr_in hostAddress;
if (isStarted())
return (FTALK_ILLEGAL_STATE_ERROR);
// Note: For TCP we allow 0 as slave address, -1 means ignore slave adr
if ((slaveAddr < -1) || (slaveAddr > 255))
return (FTALK_ILLEGAL_ARGUMENT_ERROR);
this->slaveAddr = slaveAddr;
// Special treatment for the Win32 platform, needs to load WinSock DLL
#ifdef _WINSOCKAPI_
WSADATA wsaData;
result = WSAStartup(0x0101, &wsaData);
if (result != 0)
return (FTALK_SOCKET_LIB_ERROR);
#endif
// Open socket
listenSocket = socket(PF_INET, SOCK_STREAM, 0);
if (listenSocket == INVALID_SOCKET)
shutdownServer();
return (FTALK_OPEN_ERR);
// Configure listen socket options (we ignore errors here)
#ifdef SO_REUSEADDR
tcpOption = 1; // Enable option
setsockopt(listenSocket, SOL_SOCKET, SO_REUSEADDR,
(char *) &tcpOption, sizeof (tcpOption));
#endif
// Binding the listen socket to the port
hostAddress.sin_family = AF_INET;
if ((hostName == NULL) || (hostName[0] == '\0'))
hostAddress.sin_addr.s_addr = htonl(INADDR_ANY);
hostAddress.sin_addr.s_addr = inet_addr((char *) hostName);
#if !defined(__VXWORKS__) // We don't support host name resolving with VxWorks
if (hostAddress.sin_addr.s_addr == INADDR_NONE)
struct hostent *hostInfo;
hostInfo = gethostbyname((char *) hostName);
if (hostInfo == NULL)
return (FTALK_TCPIP_CONNECT_ERR);
hostAddress.sin_addr = *(struct in_addr *) hostInfo->h_addr;
#endif
hostAddress.sin_port = htons(portNo);
result = bind(listenSocket, (struct sockaddr *) &hostAddress,
sizeof (hostAddress));
if (result == SOCKET_ERROR)
shutdownServer();
switch (socketErrno)
#ifdef _WINSOCKAPI_
case WSAEACCES:
return (FTALK_PORT_NO_ACCESS);
case WSAEADDRINUSE:
return (FTALK_PORT_ALREADY_BOUND);
case WSAEADDRNOTAVAIL:
default:
return (FTALK_PORT_NOT_AVAIL);
#else
case ENOTCONN: // Linux 7.2 reports this error no if no root privilege
case EACCES:
case EADDRINUSE:
case EADDRNOTAVAIL:
default:
#endif
// Start listening to incoming connections
result = listen(listenSocket,
((MAX_CONNECTIONS < SOMAXCONN) ? MAX_CONNECTIONS : SOMAXCONN));
shutdownServer();
return (FTALK_LISTEN_FAILED);
return (FTALK_SUCCESS);
serverLoop()
int iReturnCode = (FTALK_SUCCESS);
int result;
int sockIdx;
int recvResult;
int sendResult;
fd_set fdSet;
timeval timeVal;
SOCKET maxFileDes;
int replyCnt;
int tcpOption;
if (!isStarted())
// Prepare file descriptor set for select call
FD_ZERO (&fdSet);
#ifdef _MSC_VER
# pragma warning(push)
# pragma warning(disable: 4127)
#endif
FD_SET (listenSocket, &fdSet);
#ifdef _MSC_VER
# pragma warning(pop)
#endif
maxFileDes = listenSocket;
for (sockIdx = 0; sockIdx < MAX_CONNECTIONS; sockIdx++)
if (connectionSocketArr[sockIdx] != INVALID_SOCKET)
#ifdef _MSC_VER
#endif
FD_SET (connectionSocketArr[sockIdx], &fdSet);
#ifdef _MSC_VER
#endif
if (connectionSocketArr[sockIdx] > maxFileDes)
maxFileDes = connectionSocketArr[sockIdx];
// Block until accept request or received data or time-out
timeVal.tv_sec = (long) timeOut / 1000L;
timeVal.tv_usec = ((long) timeOut % 1000L) * 1000L;
if (timeOut == 0)
result = select((int) maxFileDes + 1, &fdSet, NULL, NULL, NULL);
result = select((int) maxFileDes + 1, &fdSet, NULL, NULL, &timeVal);
return (FTALK_FILEDES_EXCEEDED);
// Check for time-out
if (result == 0)
TRACELOG1("Slave poll time-out!\n");
dataTablePtr->timeOutHandler();
iReturnCode = (FTALK_REPLY_TIMEOUT_ERROR);
// Connection accept request
if (FD_ISSET (listenSocket, &fdSet))
// Search a free socket
if (connectionSocketArr[sockIdx] == INVALID_SOCKET)
struct sockaddr_in peerAddr;
SOCK_LEN_TYPE peerAddrLen = sizeof(peerAddr);
// Yes, socket is free, try to accept a connection on it
connectionSocketArr[sockIdx] = accept(listenSocket,
(struct sockaddr *) &peerAddr,
&peerAddrLen);
// Check id connection shall be accepted
if (!dataTablePtr->validateMasterIpAddr(inet_ntoa(peerAddr.sin_addr)))
shutdown(connectionSocketArr[sockIdx], SD_BOTH);
closesocket(connectionSocketArr[sockIdx]);
connectionSocketArr[sockIdx] = INVALID_SOCKET;
TRACELOG2("Connection rejected on slot %d\n", sockIdx);
// Set socket options (we ignore errors here, not critical)
#ifdef TCP_NODELAY
setsockopt(connectionSocketArr[sockIdx],
IPPROTO_TCP, TCP_NODELAY,
#endif
#ifdef SO_SNDBUF
tcpOption = MAX_MSG_SIZE;
SOL_SOCKET, SO_SNDBUF,
#endif
#ifdef SO_RCVBUF
SOL_SOCKET, SO_RCVBUF,
#endif
#ifdef SO_LINGER
tcpOption = 0; // Disable option = discard unsent data when closing
SOL_SOCKET, SO_LINGER,
#endif
TRACELOG2("Connection accepted on slot %d\n", sockIdx);
break; // Leave for loop
// Data received on socket
if (FD_ISSET (connectionSocketArr[sockIdx], &fdSet))
recvResult = recv (connectionSocketArr[sockIdx],
(char *) bufferArr, sizeof (bufferArr), 0);
sendResult = 0;
replyCnt = 0;
// Process client message
if (recvResult >= PREFIX_LEN) // Process only minimum message sizes
short dataLen;
dataLen = (short) ((bufferArr[4] << 8) | (bufferArr[5] & 0xFF));
// Validate length before processing message
if ((dataLen + PREFIX_LEN) == recvResult)
replyCnt = processMessage(&bufferArr[PREFIX_LEN],
recvResult - PREFIX_LEN);
// The first two bytes (msg id) are returned untouched
bufferArr[2] = 0; // protocol identifier
bufferArr[3] = 0; // protocol identifier
bufferArr[4] = (char) ((replyCnt) >> 8);
bufferArr[5] = (char) ((replyCnt) & 0xFF);
sendResult = send(connectionSocketArr[sockIdx],
(char *) bufferArr,
replyCnt + PREFIX_LEN, 0);
// Check for disconnection and errors
if ((recvResult < PREFIX_LEN) ||
(sendResult != replyCnt + PREFIX_LEN))
// Free socket
if (recvResult == 0)
TRACELOG2("Disconnected slot %d nicely by other peer.\n",
sockIdx);
TRACELOG2("Forced disconnection on slot %d!\n", sockIdx);
return iReturnCode;
