Send and receive data thru Eth w/ PIC16F
Jasen
PostPosted: Thu Dec 26, 2013 6:41 pm     Reply with quote
Hi, I bought a board with Ethernet RJ45 and ENC28J60 built in. Do you have any example software (with pic 16F) to send and receive data thru this board (SPI). Let’s suppose an Ethernet net ...lets example a PC sending data thru eth to a PIC. Depending of data sending, its turn on a LED...
PostPosted: Thu Dec 26, 2013 8:14 pm     Reply with quote
comment: Have you looked in the examples folder that CCS supplies? A fairly recent version of the compiler probably has a sample code there.
If not, try the 'code library' here,some one might have posted their efforts there.
hth
jay
asmallri
Re: Send and receive data thru Eth w/ PIC16F
PostPosted: Fri Dec 27, 2013 7:31 am     Reply with quote
Don't waste your time. A PIC16f series does not have the resources or memory structure to do anything useful with this controller and a top/ip stack.
Regards, Andrew
jgschmidt
PostPosted: Fri Dec 27, 2013 10:09 am     Reply with quote
If you have an Ethernet network communication requirement then look at the Wiznet 5100 boards out there. They handle the TCP/IP heavy lifting and you can talk to them via serial port. This allows you to connect anything with a serial port to a TCP/IP network and the Internet. The WIZ105SR and WIZ110SR boards are my favorites for this. They're available from most electronics suppliers.
Jürgen
www.jgscraft.com
