		| Author | Message |
		| pilar
				| Warning !! (SOLVED) |
				|  Posted: Thu Nov 28, 2013 11:20 am |   |
				| Hi, someone can tell me how I can remove this Warning, it is affecting my program.
  	  | Code: |  	  | Executing: "D:\Archivos de programa\Microchip\PICC\Ccsc.exe" +FH "RTC1.C" +DF +LN +T +A +M +Z +Y=9 +EA >>> Warning 203 "D:\Proyectos\Poste_SOS\CCS-PIC\DS1307.h" Line 123(1,1): Condition always TRUE
 >>> Warning 216 "RTC1.C" Line 616(0,1): Interrupts disabled during call to prevent re-entrancy:  (Ini_buff_rec)
 >>> Warning 216 "RTC1.C" Line 616(0,1): Interrupts disabled during call to prevent re-entrancy:  (@delay_ms1)
 >>> Warning 216 "RTC1.C" Line 616(0,1): Interrupts disabled during call to prevent re-entrancy:  (inicbuff)
 >>> Warning 202 "RTC1.C" Line 11(5,8): Variable never used:   rs232_errors
 Memory usage:   ROM=30%      RAM=13% - 14%
 It may be that someone might have the same problem...
 http://www.ccsinfo.com/faq.php?page=interrupts_disabled
		| temtronic
				|  Posted: Thu Nov 28, 2013 12:20 pm |   |
				| Actually 'warnings' do not affect programs. The first 3 tell you that interrupts are disabled within an ISR, This is normal and will not affect your program
 The 4th says that a variable is never used,again normal.
 Warnings will NOT stop the compiler from creating executable code,meary inform you of a 'condition'.
 Now if your program doesn't work, then post it(or a small,compilable one) that shows us what's going on..or...better explain why you want the 'warnings' to not appear.
 hth
 jay
 | You cannot post new topics in this forum You cannot reply to topics in this forum
