RC522 RFID module SPI
Goto page 1, 2, 3, 4, 5  Next
josb86
PostPosted: Tue Oct 29, 2013 11:00 am     Reply with quote
I am trying connect a RC522 RFID module SPI to a pic16F887 but I can't make that this read the code in a RFID card.
datasheet of MFRC522 http://www.nxp.com/documents/data_sheet/MFRC522.pdf
http://www.ebay.com/itm/Mifare-RC522-Card-Read-Antenna-RF-Module-RFID-Reader-IC-Card-Proximity-Module-/170846290768
#include <pru_spi.h>
#use SPI( MASTER, baud = 100000, DO = PIN_C5, DI = PIN_C4, CLK = PIN_C3, ENABLE=PIN_C2, BITS = 8, MSB_FIRST, stream = RFID, ENABLE_ACTIVE=1 )
#use rs232(baud=9600,parity=N,xmit=PIN_C7,rcv=PIN_C6,bits=8,stream=RF)
   setup_comparator(NC_NC_NC_NC);// This device COMP currently not supported by the PICWizard
   int i=0;
   Char value[8];
   INT8 t_bucle=0;
   output_high(pin_C2);
   fprintf(RF,"%s\n\r",value);
   value[0] = spi_xfer(RFID, 0b10000000);
   output_low(pin_C2);
the output on serial port RF blank. Anybody help with this module?
gpsmikey
PostPosted: Tue Oct 29, 2013 11:59 am     Reply with quote
What is your schematic look like? What supply voltage are you using - while the pic16F887 will do 5v, the RFID looks like it is 3.3v only - are you using 3.3v or 5 v?
mikey
mikey
old engineering saying: 1+1 = 3 for sufficiently large values of 1 or small values of 3
josb86
I am use a 3.3 power supply for the pic and the rfid reader.
PostPosted: Tue Oct 29, 2013 1:35 pm     Reply with quote
I am use a 3.3 power supply for the pic and the rfid reader. the conection:
SS to PIN_C2
SCK to PIN_C3
MOSI to PIN_C5
MISO to PIN_C4
GND to GND
RST to GND
+3.3 to 3.3v
PostPosted: Tue Oct 29, 2013 2:29 pm     Reply with quote
Post this file so we can see your #fuses and everything.
Look at this timing diagram on page 78 of the MFRC522 data sheet:
Fig 25. Timing diagram for SPI
It shows the NSS signal (ie., slave select for the MFRC522) is a low true
signal. But you have it set for high true in the #use SPI() statement
above. Fix that.
Also, in the #use spi() line above, you don't have FORCE_HW specified
so the CCS compiler will put in software SPI code. It will use bit-banging
to do the SPI. I'm just making you aware of that.
Also, in the #use spi() statement, you didn't specify the SPI mode.
That's important. The MFRC522 appears to use Mode 0. You need to
add a parameter to the #use spi() to specify that. See the CCS manual.
Here you have reversed the pins from the hardware assignments on the
16F887. Look at the pinout for the 40-pin package in the 16F887 data
sheet. Because you have done this, the compiler will create a software
UART on those pins. And, it won't inform you of this. Change the pins
to the correct pins for the hardware UART. Then you'll get hardware UART
code from the compiler. Also, we like to add the ERRORS parameter
to the #use rs232() statement above.
int i=0;
Char value[8];
INT8 t_bucle=0;
Variable declarations go at the start of a function. Don't put lines of
code above any variable declarations. Also, you're changing the case
and you're using aliases for data types. This is very poor technique.
CCS is case-insensitive by default. Most C compilers are not. It's a bad
habit to get into. Also 'int' is the same as 'int8' in CCS. They are both
unsigned 8-bit integers. It's suggested that you use 'int8' when writing
CCS programs.
output_low(pin_C2);
Here, you are manually controlling the Slave Select line on pin C2.
But you have told the compiler to do it in the #use spi() statement.
So why do it manually again ? It's not needed. And the way you're
doing it is incorrect, because the MFRC522 data sheet shows that
Slave Select is active low. You're controlling it as if it's active high.
It wouldn't work. Get rid of those two lines in bold above.
ckielstra
PostPosted: Tue Oct 29, 2013 3:01 pm     Reply with quote
Such a short program and so many problems detected by PCM Programmer. Wink
Couldn't help myself to point another problem:
   output_low(pin_C2);
Printing a value with %s requires a string, i.e. an array of bytes terminated by a zero. Yours is not zero terminated.
Using %c would have fit your job perfectly without the need for an array.
josb86
PostPosted: Tue Oct 29, 2013 3:32 pm     Reply with quote
#include <16F887.h>
#device adc=16
#FUSES HS                       //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES PUT                      //Power Up Timer
#use delay(clock=20000000)
if I understand, if I set the serial com for software I can put the TX and RX where a needed.
josb86
PostPosted: Tue Oct 29, 2013 4:18 pm     Reply with quote
   output_low(pin_C2);
thanks, one less problem.
PostPosted: Tue Oct 29, 2013 4:38 pm     Reply with quote
You do that, but a software UART is not nearly as good as a hardware
UART, and if you have the hardware UART available you should use it.
I'm about done with this thread.
josb86
PostPosted: Tue Oct 29, 2013 4:53 pm     Reply with quote
Ok thanks for all Wink I learned some things today.
I find this library for arduino, I hope this help me
https://github.com/JoyLabs/arduino/blob/master/libraries/RFID/MFRC522.h
PostPosted: Wed Oct 30, 2013 1:12 am     Reply with quote
I suggest you start by reading the PIC data sheet.
What clock rate is the maximum if you are running at 3.3v?. It is _not_ the normal full speed of the processor. To run at 20MHz, requires a supply of 4.5v or greater....
You may find things start to work, if you change your crystal for a 10MHz one, and recompile to use this speed.....
josb86
PostPosted: Wed Oct 30, 2013 9:35 am     Reply with quote
I will try to work with 5v source on PIC, thanks.
PostPosted: Wed Oct 30, 2013 9:45 am     Reply with quote
Hardware SPI won't work then to your module.....
Requires the signals to go up to about 4v when running at 5v.
Better to either switch to a more modern chip that can run at 20MHz at 3.3v, or go down to 10MHz.
tienchuan
View user's profile Send private message Yahoo Messenger
PostPosted: Tue Dec 10, 2013 12:01 am     Reply with quote
Have anyone tested with this module OK?
I'm having a trouble when doing with it.
The module can't not read mifare S1 card.
Begin Begin Begin !!!
electromaker
Test RC-522
PostPosted: Thu Jul 07, 2016 1:56 pm     Reply with quote
Hi everyone,
I have tested module RC-522 with Arduino 2009...I have used the code of this tutorial http://etabetastudio.blogspot.it/2016/07/tutorial-lettore-rfid-rc522-arduino-idea.html and all is ok,
I hope that it can help you.
Bye Smile
sambo
PostPosted: Tue May 30, 2017 10:58 pm     Reply with quote
Can anyone share working code for RC522 ?
sory for my eng
Page 1 of 5
